Making two buttons reset+power to turn on computer when pushed together?
4,520 (0.69/day)
Perth AU
Processor Intel Core i9 10980XE @ 4.7Ghz 1.2v
Motherboard ASUS Rampage VI Extreme Omega
Cooling EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
Memory G.Skill Trident Z RGB F4-3000C14D 64GB
Video Card(s) Asus ROG Strix GeForce RTX 4090 OC WC
Storage M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos
Display(s) Samsung Odyssey G7 28"
Case Corsair Obsidian 500D SE Modded
Power Supply Cooler Master V Series 1300W
So short story is my sister wants her computer made so you need to push two buttons to turn it on and off, The reason why is she has kids that love pushing buttons, I don't want ideas of other ways to go all i want is the best way to wire it because the few ways I've tried seem to work randomly lol.
12,062 (2.54/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
The simple purpose of a power button is to short those two pins on the motherboard header. Simply put, unplug the silly pins for the reset switch. Send the + cable to the reset button, then - cable to the power button, and then run a cable between the two buttons, as essentially all they need to do is complete a circuit to enable the short.
the54thvoid
Super Intoxicated Moderator
13,586 (2.42/day)
Memory 32GB Kingston Fury
Video Card(s) MSI RTX 5080 Vanguard SOC
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
Well, requiring a two button push wont stop them. Random pressing will still yield the same tampering. Why not just go the extra 3 seconds to switch off/on PSU at back of PC? You can also not connect the reset switch fro the case to the mobo header, that would stop instant reset. As for power, you can use windows to change the function of the off button to do nothing, or sleep etc.
12,062 (2.54/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
4,520 (0.69/day)
Perth AU
Her older kids use the computer its more a problem them going up when its on and turning it off when the others are using it. Will also stop them turning it on.
12,062 (2.54/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
User-based-lobotimising-device. If the wrong user walks into the room where the PC is situated, WHAM. Instant lobotomy. That'll teach 'em.
the54thvoid
13,586 (2.42/day)
Software W10
Her older kids use the computer its more a problem them going up when its on and turning it off when the others are using it.....
That would be stopped by the power function in windows - disable the power off feature. You'd need to use 'shut down' command from inside windows.
4,520 (0.69/day)
Perth AU
Yer but rather just do as my sister wants lol. I cant seem to get it working though i cut the power button into the reset.
4,520 (0.69/day)
Perth AU
Well it would help if the dam reset button worked which it didnt does now.
42 (0.01/day)
Hamburg,Germany
System Name My PC
Processor Rysen 5 2600
Motherboard Gigabyte B450M DS3H
Cooling BeQuiet Dark Rock Advanced
Memory 2x8 G.Skill DDR4-2132
Video Card(s) Gigabyte 1080 turbo
Storage LiteOn 256GB SSD,Seagate 2TB+WD 4TB
Display(s) LG 29UC97C-B
Case Custom
Power Supply XFX Core 750W sleeved
4,520 (0.69/day)
Perth AU
Yep its working now, buttons don't have a + and - do they so shouldn't mater which way they are used?
42 (0.01/day)
Hamburg,Germany
System Name My PC
Case Custom
Most of the times the wires with same color are - ,but since thats short curcuit,it doesnt matter.
3,008 (0.59/day)
Do you have a second button, and is this computer a tower?
The reason I ask is because a tower is simple. The motherboard signal to reset is just a momentary on switch. You complete the circuit, power is delivered back to the motherboard header pin, and the computer knows to restart. Assuming this, get a secondary momentary on switch, and then wire them in series. A physical distance between the buttons is the easiest way to prevent accidental presses.
The ghetto mod version of this is taking to switch from another case, and slicing off the header connection on it. Take the current switch, and cut about half way between the header and switch on one of the wires. Take the switch you've cut the header off, and splice its wires into the switch you've cut half way. You'll have to press both buttons now in order to get a reset signal.
Alternatively, get a rotary key switch and wire it into series with the momentary push button switch. The computer cannot reboot if the key isn't rotated into place, and no amount of button pressing will allow it to happen. Of course, this means you'll have to keep the key somewhere nearby in case you actually need to reset the system.
If you're looking at a laptop, good luck. Modification there is a joke, so you should try going into software and changing button press requirement times. This also works on a desktop, but isn't an idiot resistant solution.
Edit:
To those who don't get how this works, let me explain.
The reset and power switches always have power running in them. The reason your computer doesn't power cycle is because there is no path to ground, because the switch is breaking the circuit (NO, or normally open switches are used). This means that a small piece of metal, like a screwdriver, could jumper the motherboard header pins and send the signal to boot-up.
The only reason polarity comes into play is for lighting. LEDs are utilized to indicate HDD activity and power. An LED is a light emitting diode, and diodes only pass power in one direction. Assuming that old school bulbs are used, the headers don't need to be marked for polarity at all.
2,074 (0.45/day)
Jacksonhole Florida
System Name DEVIL'S ABYSS
Processor i7-4790K@4.6 GHz
Motherboard Asus Z97-Deluxe
Mouse Ttsports Talon Blu
Keyboard Logitech G510
Tell the little ones that they'll be put up for adoption if they don't quit pressing the damn buttons. The first time one of them pushes the button, follow through and actually let another family adopt the little miscreant, the others will never push another button again...
2,098 (0.51/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
Couldn't you disconnect the power button and make the pc turn on by typing a code on keyboard.
4,520 (0.69/day)
Perth AU
My nephew is only 3 and he wont turn it off when his mums using it but if hes brothers playing minecraft he will turn it off then run off, I find it funny but windows doesn't seem to like it much lol, The computers in a prodigy case so all the wires are black so its hard to tell but it seems to be working now so i must of got it right the 2nd time around thanks guys.
He also rips buttons of his days G19 keyboard and pull the wires out of his headphones lol.
2,074 (0.45/day)
Jacksonhole Florida
This is the price we must pay for the age of electronics (and beatings being outlawed). When I was 3 if I so much as looked at my Dads stereo or TV, I'd be severely beaten. I still have to call him (long distance) every time I want to turn something on, or my ass starts hurting...
