MeLE QuieterDL is an Intel N100-powered Mini PC With Dual 2.5 GbE Ethernet
GGforever
Staff
197 (1.05/day)
The MeLE QuieterDL is a freshly launched mini PC with a footprint that is barely larger than a smartphone. The system is available to purchase on Amazon, starting at $159.99. At that price, it is hardly fair to expect powerhouse performance, although the QuieterDL mini PC does live up to its name by sporting a fanless design.
At its core, the system is powered by an Intel N100 CPU. The processor is by no means a screamer, but its quad-core setup with a maximum clock speed of 3.4 GHz should be enough for most day-to-day tasks that are sufficiently lightweight such as managing emails, casual web browsing, and content consumption. The system can be specced with either 4 GB or 8 GB of LPDDR4 RAM, while storage configurations range from 128 GB to 512 GB of NVMe storage, which, thankfully, can be upgraded to a maximum of 4 TB down the line courtesy of its M.2 2280 slot.
That being said, the port selection is actually pretty decent, all things considered. The mini PC boasts dual 2.5 GbE Ethernet, USB-C, triple USB-A 3.0, USB 2.0, HDMI 2.0, DisplayPort 1.4, as well as an audio jack. Wireless connectivity is present as well, made possible by Wi-Fi 5 and Bluetooth 5.1. As previously mentioned, the 4 GB + 128 GB variant of the QuieterDL sells at $159.99, whereas the highest-end 16 GB + 512 GB variant can be purchased for $249.99.
6,662 (1.58/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
"cheap is as cheap does"....
It looks aesthetically pleasing, but seriously, just spend about $100-150 more & get a better spec'd mini-me box with better wireless & all the other goodies, which is the same or less than you'd spend on upgrading this box to decent spec's anyways, unless you already have the ram & m.2 from a previous machine....
Note that if this is limited to 8GB of ram, that won't get you very far if it's gonna run Windblows...although linux would probably be ok with it though :D
1,223 (0.20/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 990PRO 2TB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/9qw7iq https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
"Dual 2.5 GbE Ethernet"
Almost there!!!
Integrated 10Gbps NIC
Easy Rhino
Linux Advocate
15,685 (2.33/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
Seems like just another product destined for the landfill in 1.5 years.
7,238 (1.06/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
Nice little fit-in-pocket server box or firewall.
216 (0.13/day)
Processor 265K (running stock until more Intel updates land)
Motherboard MPG Z890 Carbon WIFI
Cooling Peerless Assassin 140
Memory 48GB DDR5-7200 CL34
Video Card(s) RTX 3080 12GB FTW3 Ultra Hybrid
Storage 1.5TB 905P and 2x 2TB P44 Pro
Display(s) CU34G2X and U2724D
Case Dark Base 901
Audio Device(s) Sound Blaster X4
Power Supply Toughpower PF3 850
Mouse G502 HERO/G700s
Keyboard Ducky One 3 Pro Nazca
Hoping next generation brings proper HDMI 2.1 support (ADL-N is only HDMI 2.0 bandwidth) then something similar to this could make a really fantastic HTPC.
Packabowl09
15 (0.02/day)
Why? something lacking from the n100 that is going to make microsoft no longer support it?
More like lack of support from the Manufacturer. Sometimes you need to reinstall Windows, and it's way harder to get up and running if they don't have a product support page with driver downloads.
I bought a mini PC from Minisforum, which is one of the more well-known brands, and it was impossible to download drivers for it from their website. I had to go into their Discord channel to ask around to find out exactly which NIC is used so I could download the driver from the NIC manufacturer. After a couple hours of tracking down each driver, I still had a couple missing system devices in Device Manager.
74 (0.33/day)
4GiB of RAM? Don’t do it, I’m writing this from my main machine, which, incidentally, has remained on 4GiB. Running Void Linux with Wayfire, so no Desktop Environment, even, and Firefox is constantly driving me insane with its RAM hunger. I have zRAM for swap (swap to compressed memory), and set it up to plenty amounts as well. It’s just … I wish software was better, about seven years ago on Vista I’ve crammed a lot into the same amount of RAM, but, it’s just not really bearable anymore. I guess if you only want to open some webpages, not many, and few of them are, say, YouTube or Instagram (two pages I’ve noticed driving up memory demands), then yes, OK, fine, it’ll run. Other than that, no. The processor is much less of a limit there.
… Besides that: Dual 2.5Gb Ethernet but 802.11ac WiFi!? The whole configuration seems so asinine, I must be missing out on any reason it’d make sense.
People have mentioned using it as a portable FW? Uhh, I guess? Is the faster Ethernet really a requirement there, seeing as but a small fraction of a minority I can envision firewalling anything but towards the Internet? I mean, some people do have very fast lines. Hmm.
1,235 (1.03/day)
Ah yes that could be a problem, had the same thing with a sony laptop that didn't bother bringing a touch screen driver to windows 10
