Memory help needed please.
443 (0.07/day)
BY-S36
System Name Bitch / Dogma
Processor 955 BE @ 3.8Gig / 9850 @stock
Video Card(s) 8800 GTX 512 / 4890
Storage 8 x Samsung F2 1.5TB, 8 x Seagate 500s
Display(s) Acer 24 / Dell 24
Case Lian li / Akasa
Software Win server 2008 / Win 7
A fairly straight forward question I hope:
At present I have 2 dell PCs acting as home servers (1 Ubuntu, 1 Windows)
These PCs each have 2 x 512Mb PC2-3200 installed
I want to buy each PC 2 x 1Gb...however PC2-3200 memory is a stupidly high price.
Will PC2-6400 memory work?
Current memory details from CPU-Z
Dram freq - 200MHz
CAS - 3
RCD - 3
RAS -3
Cycle - 8
Volts - 1.8
I am considering New Memory
Any issues that you can see?
Many thanks in advance
Ddr2 doesn`t work in ddr slots, if that`s what you`re asking.
Depends on if your mother boards in those 2 support it or not...You will have to look it up!!
Your motherboard only supports DDR memory, not DDR2. You cannot use DDR2 memory.
The current memory is DDR2 3200
I want to install DDR2 6400 (obviously running and 3200 speeds)
With regard to the motherboards, they are Dell 0H8367, Intel i915P/i915G chipset, Southbridge Intel 82801FB(ICH6):confused:
It looks like i may have answered my own question with the help of Crucials compatibility guide:
Model: Dell Optiplex GX280 (Small form factor)
Number of slots: 2
Each memory slot can hold DDR2 PC2-4200,DDR2 PC2-5300,DDR2 PC2-6400 with a maximum of 1GB per slot.
I'm now a happy panda and can order my upgrades!
depends on mobo and cpu. what cpu/mobo you have? Nvm i got it. You can buy it if the cpu can handle it.
