Hi all, and thanks for the help with getting my FX9590 up and running!
I have another project that I'm having an issue with. Last year I found an old AlienWare Area-51 desktop with the original Pentium IV still chugging away. The owner just didn't want it anymore, and had left it on the curb for recycling. I asked, and received his permission to bring it home. I've repainted the case(can't stand that lime green color!) to look like an old grey alien, with cracked skin showing dark blue underneath. I put the following stuff into it:
GigaByte GA-Z87X-OC motherboard.
Intel Core i5 4690 CPU.
32 Gb(4x8Gb) Hynix server-RAM(PC-3 10600R 1333Mhz) ECC registered DDR3.
Radeon RX570 video card.
RotM 750Gb and RotM 1Tb hard drives, and a RotM DVD; all SATA.
EVGA 750W power supply.
So...when I turn the machine on, the "power" LED on the MB illuminates, the the drives spin up, and an LED on the RX570 lights up. Then I get beeps...LOTS of beeps VERY rapidly. In the space of about 5 seconds, I'd say I get between 25 and 30 beeps, then the system restarts and repeats. Until I remove power this cycle continues repeating. The DeBug LED shows either a "15" or a "51"...I'm not sure how it's supposed to be read in relation to the MB. The "15" code states "Pre-memory North-Bridge initialization is started." The "51" code states "50-55: Memory initialization error occurs." Some reading on the internet also revealed that "constant" beeping might be caused by an incorrectly installed video card.
I've removed and reinstalled the memory, and I've removed and reinstalled the video card without any change. I then removed the video card completely and plugged my HDMI cable into the MB 'video' output. There was still no change in the symptoms. It seems I'm looking at a memory issue; could the memory I purchased be incompatible with the motherboard? Prior to purchasing I contacted the seller and stated which MB I was planning to install their memory into, and they assured me that the RAM listed above was compatible.
Would anyone like to help me out here?
Rick
Rick
