- Feb 15, 2009
- 649 (0.11/day)
- Norway, which means Amazon is not available...
System Name | Winter v3.2024 |
Processor | Intel i7 12700K (since november 2021) |
Motherboard | Gigabyte Z690 Gaming X (since november 2021) |
Cooling | Air Liquid Freezer II 360 with LGA1700 kit (since november 2021) |
Memory | Crucial Ballistix 2x16gb 3600mhz C16 (since november 2021) |
Video Card(s) | Gigabyte RTX 3060 Ti Gaming OC Pro LHR - Rev3.0 (since july 2022) |
Storage | 1x 1TB WD Blue SN570 SSD, 1x Seagate 4TB SATA |
Display(s) | 1x 55" LG C1 4k OLED, 1x Gigabyte 32" M32Q and 2x AOC 27" CG1 |
Case | Fractal Design Define R6 (since 2018 and still working like a charm!) |
Power Supply | Corsair RM850x black (since august 2022) |
Mouse | Razor Deathadder v2 (since december 2021) |
Keyboard | Varmilo VEA109 v2 MX Silent Red (since august 2022) |
Software | Windows 11 Pro |
Noobie looking for help/pointers once again...
I currently own 3x Deco S4, that we are quite happy with. I previously had 1x Ubiquiti AC Lite, which didn't work well enough for me and my neighboring house. The S4 seemed to be the solution to our coverage problems, since it was just plug-n-play, pretty much. And easy to maintain and keep track of as well. Stable wifi speed as well.
However, IF i were to upgrade from the Deco S4, which mesh system gives MORE coverage than the S4 and that's also just plug-n-play and nothing overly fancy? Budget: About the same as Deco S4 + about €/$50 extra.
TP Link's M9 Plus is a tad above my budget, unfortunately. Great coverage it seems, but too pricey. Any similar ones than those? Or, can we just buy the S4 DUO package and place them in suitable locations so we will end up having 5x S4 instead of 3x, or will that not help much?
And no, it doesn't have to be TP-Link only. I just took an example.
We are also not in a rush to upgrade. It was simply a thought i had that IF we were to upgrade, which one would be an upgrade from the Deco S4.
Like always: I am located in Norway, so we don't have everything you lot have over at the states, unfortunately.
