Microphone not working on Kingston HyperX Cloud
158 (0.04/day)
Hey guys.
Recently I've been trying to set up my mic on my headset Kingston HyperX Cloud (1 not 2), and have not succeeded, so I'm wondering if anyone can help me out here.
I've been trying to find the problem by googling it and I can't manage to find it all of them just say to make sure that the microphone is properly plugged in (which it is), make sure that the mute button is switched on the control box (which it is since I tried on both sides when switched).
I try to test it through many ways but it still I don't succeed.
Any suggestions ?
Thanks.
95Viper
Super Moderator
13,309 (2.20/day)
A little info may be helpful... how about listing your system, which ports are you trying to use (like, the front or back), is it a separate sound card, and have you check any windows (or, which OS) mic/sound settings.
Did you check any settings in the audio control app ( like a Realtek app or some other one)?
Is it not working at all or just games?
Did you have a mic connected before and did it work?
158 (0.04/day)
Thanks for the reply Viper, here are the answers:
- Tried using all my ports, mic does not work on any.
- No sound cards installed only onboard.
- Checked 'Recording devices' at Windows 7 Control Panel everything is at default which should make the mic work, no mute enabled.
- I have Realtek HD Audio Manager, all settings are at default and no mute is enabled same as above.
- Not working at all, I tried different websites and programs/games to test it.
- Never connected it before.
95Viper
Super Moderator
13,309 (2.20/day)
What Motherboard and case?
Or, is it a laptop?
EDIT: Also, when you plug it in... is it recognized by the software or windows?
Did you try it on any other system?
How about without the control box?
Did you update your audio (Realtek) drivers?
In the control panel under "sounds" > "recording" > microphone
Is it enabled? Uncheck the box for apps to have exclusive control? Make mic volume is not set at 0% and tried turning the boost up and down?
Did you try the Windows Troubleshooter?
Open the Recording Audio troubleshooter by clicking the Start button
, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Hardware and Sound, click Troubleshoot audio recording.‌
If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
158 (0.04/day)
AsRock Z77 Extreme4
I don't understand what do you mean by recognized by the software or Windows, since Realtek HD Audio Manager detect's that it's plugged in, and in Recording Devices it Windows detects it there also.
Didn't tried it on any other system, will try it tho.
Same without control box.
95Viper
Super Moderator
13,309 (2.20/day)
158 (0.04/day)
Oh sorry, did not see the edit.
Anyway the drivers are updated.
Microphone is enabled in Control Panel > Sounds > Recording
Troubleshooter shows no problems.
And as for Device Manager, nothing shows up (like Yellow exclamation mark).
95Viper
Super Moderator
13,309 (2.20/day)
Don't take this the wrong way; but you are not using the splitter, are you?
You are putting the mic in the pink connector and the headphones in the green.
And, you have made sure the microphone is plugged securely in the headset.
