Mionix naos 7000 scroll wheel click is not working, new mouse
2,071 (0.44/day)
Denmark
Processor I5 13400f
Motherboard asus Z790 Prime
Cooling Thermalright Assassin X120 R SE Black
Memory G.Skill Ripjaws S5 DDR5-6400 - 32GB - CL32
Video Card(s) Asus GeForce® RTX 5060 Ti 16GB Prime
Storage 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives
Display(s) LG 32GP850, IIyama G2470HSU-B1
Case DUTZO C731 Mesh TG ARGB
Audio Device(s) Yamaha R-N800A System audio signature 5 + Audio pro addon sub 1
Power Supply Corsair RM850X White
Mouse Asus Rog Gladius III Wireless Aimpoint
Keyboard Corsair K70 RGB TKL Champion
Software Windows 11 64 bit
My scroll wheel on my mionix naos 7000 is not working, when i use the scrool wheel to click on a link it will not open the link in antoher tab
Triede updating firmware and changing usb port, mabye it will work when i reboot (or not)
so what is your advice on a new mouse
Light mouse with side button and precise sensor (mousepad corsair mm300), ergonomic is very important since i really can't say i hade problems with my hand because of my mouse and i use my mouse many hours everyday
I love my Logitech G502, adjustable weight, good ergonomics, plenty of buttons without having too many, excellent scroll wheel.
What's your budget? Do you prefer wired or wireless? Do you need switchable DPI options?
I really don't have a budget, since i have an usb tv tuner i have problems getting to work, that i might have to return
Mionix naos 7000 is the first wired mouse i have no problems with, being wired
I have dpi switch but i don't use it that often
I have thought about the logitech M705 Marathon because it reasonable priced,good battery life,fast scroll and a ergonomic mouse
it doesn't have dpi switch, im not shure about the weight difference some síts say the naos 7000 is the heaviest and other the lighter of the 2
