- Apr 28, 2012
- 232 (0.05/day)
System Name | Vegos Whispering Merlin |
Processor | from 7980XE @4,8GHz to 7740 @5,4GHz, all delided + custom IHS |
Motherboard | EVGA DARK |
Cooling | lots of BitsPower, , lots of HWLabs, eloop, Mayhems aurora |
Memory | 32GB Galax HOF OCE 3800 15/16/16/36 |
Video Card(s) | SLI HOF 1080Ti @2100MHz |
Storage | Intel 900P 280GB + Storage 1,2TB P3520 & 2TB P4500 |
Display(s) | Predator 144Hz 27" IPS |
Case | Caselabs Merling SM8 |
Audio Device(s) | Razer HS + Razer Leviatan |
Power Supply | EVGA T2 1600W |
Mouse | Logitech MX Master for work and Razer Lancehead for gaming |
Keyboard | Razer Ornata Chroma |
Software | W10Pro |
Benchmark Scores | One GPU: www.3dmark.com/spy/3203275 SLI: www.3dmark.com/spy/3460940 www.3dmark.com/fs/15137359 |
Hello all
Due to lack of the information on the internet(i know, right) or simply my inability to find it im asking you for help.
Need to cool 3990X with two 3090s as silently as possible. Preferably with 2x MO-RA3 420mm or 360mm stacked in a sandwich. Dual loop. Locked in a gutted out Apple G5 case with perforated side panels(ofc rads only).
CPU and GPUs will rarely operate at the same time - thats why i think sandwich might just work.
Rads will be cooled by 9x eloops or 4x noctuas at about 600rpm with a boost after water temp reaches 35'C - controlled by a D5 Next
The alternative would be to use 5x 420 HW Labs SR2 in a row, connected parallelly with 12 fans in between. Airflow in the direction against water flow.
Questions are:
What is thermal performance of mora3s 360/420 radiators?
What do you think about both ideas for "silent cooling" a hardware that will potentially generate about 1700W under full load?
Questions are:
