- Mar 14, 2014
- 141 (0.03/day)
- Ukiah
System Name | The Tempest |
Processor | i7 5960x Haswell-E @4.5ghz 1.26 bios vcore 3.4ghz cache 1.175v on custom water 1.86vin llc default 5 |
Motherboard | Asrock X99X Killer Fatality |
Cooling | Swiftech DDC mcp50-x pump XSPC RaystormPro waterblock Acool xt45 Supernova1260 rad 9 140mmfans 1vrmF |
Memory | 32gb 4x8gb Kingston HyperX Fury (Micron rev.b) 2400mhz 15-15-15-35 @ 3200 16-19-19-36 2T 1.41v |
Video Card(s) | AMD 6800 XT reference OC 2550~2650 1.15v mem oc 2150 Fast timing Alphacool Eisblock gpx waterblock |
Storage | M.2 2 TB SSD Seagate 4tb 5400 Western Digital 6tb 7200 |
Display(s) | 4k HDR TLC 43" 60hz TV |
Case | Antec 900 Top fan 200mm/1side/2front/1rear 120mm AC Supernova 1260 rad 9/140mm fans 1700RPM 1VRM fan |
Audio Device(s) | Onboard Realtech Logitech 5.1 surround/ Bluetooth headphones |
Power Supply | Corsair RM1000i PSU |
Mouse | Logitech |
Keyboard | Logitech |
Software | Windows 10 Pro |
Benchmark Scores | Time Spy ~20000 Extreme 7800 Fire Strike 55000 Extreme 27415 Ultra 13604 Port Royal 10032 SuperPi 8s |
I have set 1.66v vdimm ram voltage setting in the bios., and it will read out correctly at about 1.684 but - the motherboard increases the voltage once in awhile to like 1.81v to the ram! The only way I can get it to set it back is a system shutdown, rebooting does not change it back. I've tried flashing the bios and a cmos battery rtc clear, and these things do not fix the problem.
I've had this happen before also about a year ago but it stopped doing it. Started happening again. The other thing is it sets my ring/cache voltage .05v~.1v higher than usuall. ASUS Z97 Pro Wifi AC motherboard bios 3503 latest.
