Modding a Train door button to a PC power button?
33 (0.05/day)
System Name The Financial Mistake 2.0
Processor Intel Xeon w5-3435X 5.3GHz
Motherboard ASUS Pro WS W790E-SAGE-SE
Cooling Alphacool ES Jet 2U 4677, 2x480 Monsta + 1x360 Monsta / Phanteks T30 x22
Memory 4x16GB Kingston Fury Renegade Pro 7000MT/s CL32
Video Card(s) NVIDIA RTX 4090 FE
Storage 4x Samsung 990 Pro 2TB, Crucial P5 Plus 2TB
Display(s) ALIENWARE AW3423DWF
Case Caselabs TH10
Audio Device(s) Creative X3
Power Supply Corsair AX1600i
Mouse Elecom HUGE Trackball, ROG Chakram
Keyboard Mountain Everest Max
Benchmark Scores Time Spy Extreme: 19,874 Time Spy: 33,772
Hi, I have this door open button from a Class 150 sprinter train and looking to mod it into a power button but I'm not quite sure which of the 4 wires go where and if the LEDs are able to run on the same voltage as the front panel 5V header etc
I found the datasheet for the button but would like a second voice to confirm or correct me if I'm wrong here, I looked at it and found the closest matching diagram which was number 4 on page 8 and assumed wire 2 & 3 are LED+ & LED- respectively while wires 1 & 4 are the switch. Is this right?
datasheet
Certainly the existing LEDs won't work on 5V. The supply voltage is 24V. The diagram mentions 1 x 8 LEDs. If they are connected in series you can disassemble the switch and short half of them. Then you have a chance of turning them on. If not then short even more.
I'm not sure about the pin arrangement. In your photos the pins 1&2 are aligned vertical and in the diagram they are horizontal. Ideally you have a power supply to test the pins. As long as you don't shove over 100V into it you should be save. (max VDC is 137V and tolerance -30% to +25%, ideally you use as close to 24V as you can get)
That is a Deustch DT series connector, if the wiring schematic shows which pins I would get the male plug, female pins and lock and wire it up, or eliminate it.
Question:
would using -12V (if PSU is equipped) as 'ground' Work?
(As long as the assembly was isolated from the chassis)
Referencing:
There's a way to avoid changing an ENTIRE industry to get +24V to a single high-wattage device. In fact, we just need to look through ATX spec's history.
Make "-12V" required, not optional.
just invert an independent +12V Rail, already common in PSUs.
Plus, GPUs already have separate power planes; one from the slot, one from auxiliary 6/8/12-pin input(s)
I may not be a big fan of Thomas Edison, but he (and the big brains w/ big pockets that standardized US Mains Power) already figured this problem out:
Edison 3-Wire Power Distribution - https://pubmed.ncbi.nlm.nih.gov/17757744/
