mouse and keyboard problems
2,143 (0.36/day)
System Name THE MAD BEAST!!!
Processor Tinfoil rapper with some coathangers
Motherboard Graham cracker with with frosting
Cooling A shovel full of snow
Memory Grey matter out of a corpse
Video Card(s) Cat eyes
Storage A whales brain
Display(s) Cyclops eyeball
Case Inside a yetis hollowed out corpse
Audio Device(s) howling banchee
Power Supply 32 hamster on a massive wheel
Software WHo needs software when you have a box of kittens
Benchmark Scores IS gatrillions a number?
for some reason all the sudden tonight my mouse and keyboard are turning off and on and the windows is making the sound like it would if you unplugged the keyboard and mouse from the usb and plug it back in it shuts up ill hit the mouse button a couple times itll make a sound and come back on, any exsplanations its doing this while i play games and everything else. hmmm?
You tried putting them in diffrent USB Ports. Make sure theres no dirt stuck in them.
is it wireless? coz if it is check the charge level is ur mouse, keyboard mine does that when the batteries need charging
My old pc had usb failure like it was a necessity for something. After a while, it was just 2 ports on the motherboard that worked. Unplug anything thats in usb that you don't need all the time. Could help. Try other ports if you havent.
thanks guys, i think there was some dirt on the usb connections, i cleaned them off its been working fine now for awhile, lets just hope it keeps up.
