Hi. I would need an advice in this simple topic. I play a game which needs fast and very accuracy movement of the mouse and every msec matters. I can't afford expensive mouses and trying some cheap ones. for my playing a mouse with 1000-1200 dpi movement is normal because higher dpi is not very accurate to quickly stop on the spot. My problem is that I noticed some mice click have a bit lag compared to others, I mean when you click and and drag a piece and then release to put in its place, releasing is a bit slower than other mouse I had. Question is, what is the measurement of fast clicking (if there is such) to look when buying a mouse? I know dpi means - movement, ips - is sensor tracking, but fast click?
