Mouse stops working seconds of minutes after plug in
lyndonguitar
I play games
1,878 (0.34/day)
Philippines
System Name X6 | Lyndon-ROG
Processor Intel Core i7-8700k | Intel Core i7 6700HQ
Motherboard Gigabyte Z370 Aorus Gaming 5 | Asus ROG-GL552VX
Cooling Deepcool Captain 240EX
Memory 16GB Corsair Vengeance LED | 8 GB
Video Card(s) NVIDIA GTX 1080 8 GB GDDR5X | NVIDIA GeForce GTX 950M 4GB
Storage SSDs: 500GB, HDDs: 2TB, 2TB, 3TB | SSD: 250GB, HDD: 1TB
Display(s) Samsung 49" CHG90 3840x1080@144Hz, Panasonic 32" HDTV, | 15.6"1080p
Case Cougar Panzer Max
Audio Device(s) HyperX Cloud II | Corsair Gaming H1500 7.1 | ROCCAT Kave 5.1 | Edifier M3200
Power Supply EVGA 750GQ
Mouse Logitech G403 | Razer Deathadder Chroma | Logitech G302 | Mad Catz Cyborg R.A.T. 5
Keyboard Corsair Vengeance K70 Cherry MX Red
I have this mouse Madcatz Cyborg Rat 5 and It had a problem. the sensor totally stops working, the buttons and scroll wheel still works, only the sensor.
I sent it to RMA and they repaired/returned it now, but not even 1 month after return, it's starting to do this again.
This time I tried troubleshooting it to see how to fix this and what's causing it before returning it to RMA again
I observed that It works right after you plug it in, then after a couple of seconds or minutes (depending on how long it was unplugged) the sensor would stop working. If you remove and replug it in immediately it will not work. I suspect this is the mouse overheating. Is such a thing possible? anyone else who has experienced this on any mouse?
It's gonna be RMA'ed again so no problem, I just wanted to know what's causing it. or maybe the possible fixes in case it happens again when its out of warranty.
edit: little typo on the title
I've recently seen this happen with the Intel USB 3.0 driver (on all ports, even 2.0), try uninstalling it and see if that improves things.
I had a RAT 7 about 2-3 years ago which had exactly the problem you describe. Unplugging the mouse and re-plugging it was the only solution to my issue. Mine sometimes worked a whole day without issues and the next day the laser would stop working about 5-10 times a day. Before developing this issue I had a problem with only the Y-axis laser stopping to respond, while the X-axis still worked. One day it died and I don't know if I was sad for paying 100 Euro for this BS or happy that my pain and anger was over for good. Even if it was still under warranty, seeing the super-long thread about problematic RAT mice (with exactly the same problem) I decided to buy a Corsair M60 (which had just come out) then and finally got rid of this issue.
Half a year later the middle mouse button of my Corsair was dead, so I RMA'ed and got a M65 instead! lucky!
Bottom line: buy Logitech next time :p
Ditto, at least the Intel 3.0 controller on my laptop. Sometimes it works and sometimes it doesn't. Haven't had any issue with the 2.0 ports.
That is the exact same problem I had, I didn't mention it but I had the exact same one axis problem before completely losing the whole sensor.
I would definitely avoid madcatz/cyborgs/rat products in the future. lesson learned.
