Mov codec broken.
7,111 (1.00/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
My mov codec must be broken. All the *.mov files are opening, but the colors are all damaged. Any suggestions? I have tried quick time alternative as well as quicktime with the same result. Whats the best way to clean out the old codecs so I can reinstall.
1,009 (0.14/day)
South Africa
Processor Intel i7-8700k @ stock
Motherboard MSI Z370 Gaming Pro Carbon
Cooling Corsair H115i Pro iirc
Memory 16GB Corsair DDR4-3466
Video Card(s) Gigabyte GTX 1070 FE
Storage Samsung 960 Evo 500G NVMe
Display(s) 34" ASUS ROG PG348Q + 28" ASUS TUF Gaming VG289
Case NZXT
Power Supply Corsair 850W
Keyboard CoolerMaster Storm XT Stealth
VR HMD Oculus Quest 2
Same here buddy. Although mine does it with mpeg files... Don't know why? It almost looks like Digital Rights Management with Media Player 10 although it doesn't have rights management. The typical green sloshes and the like. No codecs helped unfortunately. Anyone else have an idea? :confused:
491 (0.07/day)
England, UK.
System Name Akame
Processor Intel® Core™ i7-4770K 3.5Ghz /// (Stock)
Motherboard Asus ROG Maximus VI HERO Intel Z87 Socket 1150
Cooling Stock Air Cooler
Memory 16Gb (4x4Gb) /// G Skill PC3-19200 DDR3 2400MHz
Video Card(s) EVGA GeForce GTX 970 SC GAMING ACX 2.0
Storage Samsung 840 EVO 120GB (OS) /// Samsung 840 EVO 250GB /// Western Digital Caviar 1TB Green SATAIII
Display(s) Asus 22-inch VH226H Widescreen LCD Monitor (2ms, 3000:1, 1920x1080) Full HD
Case Cooler Master HAF 932 Advanced
Audio Device(s) Astro A50 Gen1
Power Supply Corsair AX760W Full Modular 80+ Platinum
Mouse Roccat Kone AIMO
Keyboard AFX MK0217 Mechanical Gaming Keyboard
If either of you have ever installed codec packs, find them in your Add or Remove Programs application within the control panel and uninstall them first, if you don't know what the codec pack is or what codecs you have installed do the following procedures.
Go to http://www.free-codecs.com/ and go to the Codec Packs page then locate and download the XP Codec Pack (Or click here to go to the XP Codec Pack information page where you can then select download then select either the main or a mirrored location to download from).
Once downloaded, the codec pack will check to see if any other codec packs are installed and if so it will prompt you to allow it to uninstall them prior to installing the codec pack. Allow the uninstallation as it will remove all the files needed to be removed then install the codec pack I have, I can play all .mov, .mpg, .avi, .divx, .xvid, etc...
I hope this helps, if not I will try to delve further into the matter and hopefully get you both playing .mov and .mpeg files successfully :)
--Lee
W1zzard
Administrator
28,606 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
mine does that with wmv :)
491 (0.07/day)
England, UK.
System Name Akame
What video/audio players do you have and what codecs are installed on your system mate?
--Lee
W1zzard
Administrator
28,606 (3.74/day)
Memory 48 GB
not really using any, just installed a codec pack some time ago because i had to encode some videos.. now when someone sends me a link to a wmv video it's all green and messed up .. but this isnt a big deal for me since i have my dedicated media pc for all my video needs.
491 (0.07/day)
England, UK.
System Name Akame
Then that is ok, but I'd advise that you get that sorted out, I know I may not know a lot compared to you, maybe this is true or not, but it is always best knowing you can rely on your PC doing what it is supposed to do :p
I had to solve and fix two problems not long ago with my computer which I sorted with ease, first I had to repair my boot because (how it did it I don't know) it lost a file.
After that I ended up having to clean my CMOS because my computer wouldn't boot up, so I set the BIOS back to my original settings I left it as and OC'ed it to my current 2.8Ghz clock from the default 2.6Ghz.
--Lee
newmodder
669 (0.09/day)
british columbia
System Name Gamer
Processor amd phenom quad core 9950 black edition
Motherboard msi ms-7309
Cooling 120mm front,120mm rear
Memory 2gigs ddr2 800
Video Card(s) BFG gtx 260 maxcore
Storage wd 160gig sata2 hd
Display(s) LG 20in widescreen
Case USP 100
Audio Device(s) onboard Logitech x-530 5.1 spkrs
Power Supply Antec Neo 550watt
Software windows 7 Ultimate 64 bit
use divx
i always used divx codec pack and player not once had a problem, if it dont play a file then it is a corrupt one.
www.divx.com
Ralph_B
6 (0.00/day)
wmv movies - some ok , others scrambled
some of my wmv moveis play ok but others have all the colours scrambled (I mainly only use windows media player). I thought that the problem was linked to a recent video card upgrade (ati 9200 to 9550) because the files played ok before the upgrade , but I found today that the files with the scrambled colours play ok on BSPlayer. Any thoughts as to where the problem lies would be appreciated please ?
10,487 (1.37/day)
There are different versions of the Windows Media codec, one could be damaged/misconfigured in some way. That's why only few play back incorrectly.
Ralph_B
6 (0.00/day)
ok , thanks for the reply DanTheBanjoman , any pointers as to which one(s) maybe the culprit please ? :
Codec Reporting Utility Output Text
Date and Time: 27-Nov-2005 10:08:40
System Information
Operating System = Microsoft (R) Windows XP Professional (5.01.2600)
CPU Descriptor = AMD Athlon(tm) XP 2600+
CPU Clock Speed = 1916 Mhz.
Total Memory = 511 Mb.
DirectX Version = 9.0c
WMI Version = 2600.0000
ACM Version = 5.00.0
Video Codecs
AVI Decompressor
FileVersion = 6.05.2600.2749
CompanyName = Microsoft Corporation
FileDescription = DirectShow Runtime.
InternalName = Quartz.dll
LegalCopyright = Copyright (C) 1992-2001 Microsoft Corp.
OriginalFileName = Quartz.dll
ProductName =
ProductVersion = 6.05.2600.2749
AVI Draw
ProductName =
Cinepak Codec by Radius
FileVersion = 1.10.0.11
CompanyName = Radius Inc.
FileDescription = Cinepak® Codec
InternalName = iccvid
LegalCopyright = Copyright © 1992-1995 Radius Inc., All Rights Reserved
OriginalFileName = iccvid.drv
ProductName = Cinepak for Windows 32
ProductVersion = 1.10.0.0
CyberLink Video/SP Decoder
FileVersion = 5.0.0602
CompanyName = CyberLink Corp.
FileDescription = CyberLink Video/SP Filter
InternalName = CLVSD.AX
LegalCopyright = Copyright (c) CyberLink Corp. 1997-2002
OriginalFileName = CLVSD.AX
ProductName = CyberLink PowerDVD
ProductVersion = 5.0.0602
DirectVobSub (auto-loading version)
FileVersion = 1, 0, 1, 1
CompanyName = Gabest
FileDescription = VobSub & TextSub filter for DirectShow/VirtualDub/Avisynth
InternalName = VSFilter
LegalCopyright = Copyright (C) 2001-2005 Gabest
OriginalFileName = VSFilter.DLL
ProductName = VSFilter
ProductVersion = 1, 0, 1, 1
DivX 5.0.2 Codec
FileVersion = 4, 0
CompanyName = DivXNetworks, Inc.
FileDescription = DivX Video for Windows Codec
InternalName = DivX4Windows
LegalCopyright = Copyright (C) DivXNetworks 2001
OriginalFileName = DivX.DLL
ProductName = DivX Video for Windows Codec
ProductVersion = 4, 0
DivX Decoder Filter
FileVersion = 5.0.2
FileDescription = DivX (TM) Decoder Filter
InternalName = DivXDecoder.ax
LegalCopyright = Copyright © DivXNetworks, 2001
OriginalFileName = divxdec.ax
ProductName = DivX (TM) Decoder Filter
ProductVersion = 5.0.2
DivX Decoder Filter
FileVersion = 5.0.2
DScaler Mpeg2 Video Decoder
FileVersion = 0, 0, 6, 0
CompanyName = DScaler Team
FileDescription = MpegVideo Module
InternalName = MpegVideo
LegalCopyright = Copyright 2005 Michel Lespinasse, Aaron Holtzman, Gabest, John Adcock et al
OriginalFileName = MpegVideo.DLL
ProductName = MpegVideo Module
ProductVersion = 0, 0, 6, 0
DV Splitter
FileVersion = 6.05.2600.2180
InternalName = Qdv.dll
OriginalFileName = Qdv.dll
ProductName =
ProductVersion = 6.05.2600.2180
DV Video Decoder
ProductName =
DV Video Encoder
ProductName =
DVD Express Video Decoder
FileVersion = 5.01.56.00
CompanyName = Mediamatics, NSC.
FileDescription = MPEG, AC3 and LPCM Decoders
InternalName = DVD Express AV Decoder.DLL
LegalCopyright = Copyright (C) 1995-2002 National Semiconductor, Inc.
OriginalFileName = DVD Express AV Decoder.DLL
ProductName = DVDExpress
ProductVersion = 5.01.56.00
ffdshow MPEG-4 Video Decoder
FileVersion = 1, 0, 0, 1
CompanyName =
FileDescription = DirectShow and VFW video and audio decoding/encoding/processing filter
InternalName = ffdshow
LegalCopyright = Copyright © 2002-2004 Milan Cutka
OriginalFileName = ffdshow.ax
ProductName = ffdshow
ProductVersion = 1, 0, 0, 1
ffdshow Video Codec
CompanyName =
ffdshow video encoder
CompanyName =
FlyTV Platinum33
FileVersion = 5.3.2600.2180 (xpsp_sp2_rtm.040803-2158)
FileDescription = WDM Streaming ActiveMovie Proxy
InternalName = ksproxy.ax
LegalCopyright = © Microsoft Corporation. All rights reserved.
OriginalFileName = ksproxy.ax
ProductName = Microsoft(R) Windows(R) Operating System
ProductVersion = 5.3.2600.2180
Indeo® Video 4.5 Decompression Filter
FileVersion = 4.51.16.03
CompanyName = Ligos Corporation
FileDescription = Ligos Indeo® Video 4.5
InternalName = ir41_32.ax
LegalCopyright = © 1994-97 Intel Corp.; © 2000 Ligos Corp.
OriginalFileName = ir41_32.ax
ProductName = Ligos Indeo® Video 4.5
ProductVersion = 4.51.16.03
Indeo® video 5.10 Compression Filter
FileVersion = 5.2.15.58
FileDescription = Ligos Indeo XP (Indeo® Video 5.2)
InternalName = ir50_32.dll
LegalCopyright = © 1994-98 Intel Corp.; © 2000-02 Ligos Corp.
OriginalFileName = ir50_32.dll
ProductName = Ligos Indeo XP (Indeo® Video 5.2)
ProductVersion = 5.2.15.58
Indeo® Video 5.2 Compression Filter
Indeo® Video 5.2 Decompression Filter
Intel 4:2:0 Video V2.50
FileVersion = 5.1.2600.2180
FileDescription = Microsoft H.263 ICM Driver
InternalName = msh263
LegalCopyright = Copyright © Intel Corp. and Microsoft Corporation 1995-1999
OriginalFileName = msh263.drv
ProductName = Windows® NetMeeting®
ProductVersion = 3.01
Intel IYUV codec
FileVersion = 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
FileDescription = Intel Indeo(R) Video YUV Codec
InternalName = iyuv_32.dll
LegalCopyright = Copyright Intel Corporation 1992-1997
OriginalFileName = iyuv_32.dll
ProductName = Microsoft® Windows® Operating System
ProductVersion = 5.1.2600.2180
InterVideo Video Decoder
FileVersion = 5.3.5.20
CompanyName = InterVideo Inc.
FileDescription = IVIVIDEO
InternalName = IVIVIDEO.ax
LegalCopyright = Copyright © 1998-2001 InterVideo Inc.
OriginalFileName = IVIVIDEO.ax
ProductName = InterVideo Video Decoder
ProductVersion = 5.3.5.20
Ligos Indeo® Video 3.2
FileVersion = 3.24.15.04
FileDescription = Ligos Indeo® Video 3.2
InternalName = ir32_32.dll
LegalCopyright = © 1992-95 Intel Corp.; © 2000 Ligos Corp.
OriginalFileName = ir32_32.dll
ProductName = Ligos Indeo® Video 3.2 32-bit Driver
ProductVersion = 3.24.15.04
Ligos Indeo® XP Video 5.2
Ligos MPEG Splitter
FileVersion = 1.3.0.81
FileDescription = MPEG Parser Filter
InternalName = Mpeg2Parser.ax
LegalCopyright = Copyright © 2000 Ligos Corporation
OriginalFileName = Mpeg2Parser.ax
ProductName = LSX-MPEG Player
ProductVersion = 1.3.0.81
Ligos MPEG Video Decoder
FileVersion = 1.3.0.82
FileDescription = MPEG Decoder Filter
InternalName = Mpeg2Decoder.ax
OriginalFileName = Mpeg2Decoder.ax
ProductVersion = 1.3.0.82
MainConcept (AdobeEncore) MPEG Video Encoder
FileVersion = 1, 0, 0, 18
CompanyName = MainConcept AG
FileDescription = MPEG Video Encoder
InternalName = MCEVMPEG.DLL Adobe"
LegalCopyright = Copyright (C) 2001-2004 MainConcept AG
OriginalFileName = MCEVMPEG.DLL Adobe
ProductName = MPEG Video Encoder
ProductVersion = 1, 0, 0, 18
Microsoft H.261 Video Codec
FileDescription = Microsoft H.261 ICM Driver
InternalName = msh261
OriginalFileName = msh261.drv
Microsoft H.263 Video Codec
Microsoft MPEG-4 Video Decompressor
FileVersion = 8.00.00.4477
FileDescription = Microsoft MPEG-4 Video Decompressor
InternalName = mpg4ds32.ax
LegalCopyright = Copyright (C) Microsoft Corp. 1996 - 2001
OriginalFileName = mpg4ds32.ax
ProductName = Microsoft MPEG-4 Video Decompressor
ProductVersion = 8.00.00.4477
Microsoft RLE
FileDescription = Microsoft RLE Compressor
InternalName = msrle32.dll
OriginalFileName = msrle32.dll
Microsoft Screen Video Decompressor
FileVersion = 8.00.00.4487
FileDescription = Microsoft Screen Video Decompressor
InternalName = mss1.ax
LegalCopyright = Copyright (C) Microsoft Corp. 1999 - 2001
OriginalFileName = mss1.ax
ProductName = Microsoft Screen Video Decompressor
ProductVersion = 8.00.00.4487
Microsoft Video 1
FileVersion = 5.1.2600.0 (xpclient.010817-1148)
FileDescription = Microsoft Video 1 Compressor
InternalName = msvidc32.dll
OriginalFileName = msvidc32.dll
ProductVersion = 5.1.2600.0
MJPEG Compressor
ProductName =
MJPEG Decompressor
ProductName =
MPEG Video Decoder
ProductName =
Mpeg4 Decoder DMO
FileVersion = 9.00.00.3250
FileDescription = Corona Windows Media MPEG-4 Video Decoder
InternalName = mpg4dmod.dll
OriginalFileName = mpg4dmod.dll
ProductName = Microsoft® Windows Media Services
ProductVersion = 9.00.00.3250
Mpeg43 Decoder DMO
FileDescription = Windows Media MPEG-4 Video Decoder
Mpeg4s Decoder DMO
FileDescription = Corona Windows Media MPEG-4 S Video Decoder
InternalName = mp4sdmod.dll
OriginalFileName = mp4sdmod.dll
MSScreen 9 encoder DMO
FileDescription = Corona Windows Media Screen Encoder
InternalName = wmsdmoe.dll
OriginalFileName = wmsdmoe.dll
Nero Digital AVC Video Enc
FileVersion = 3, 0, 0, 5
CompanyName = Nero AG
FileDescription = MPEG4 and H.264 (AVC) video encoder
InternalName = NeroDigitalVideoEnc.ax
LegalCopyright = Copyright (c) 1995-2005 Nero AG and its licensors
OriginalFileName = NeroDigitalVideoEnc.ax
ProductName = NeroDigital
ProductVersion = 2, 6, 4, 33
Nero DVD Decoder
FileDescription = MPEG-1/2/4 & AVC video decoder w/ DxVA
InternalName =
OriginalFileName = NeVideo.ax
ProductName = Nero ShowTime
ProductVersion = 2, 0, 2, 33
Nero Video Decoder
InternalName =
QT Decompressor
ProductName =
Ulead DVD Video decoder
FileVersion = 1, 0, 0, 30602
CompanyName = Ulead Systems, Inc.
FileDescription = DVD Video Decoder with DxVA Support
InternalName =
LegalCopyright = Copyright (C) 2003 Ulead Systems, Inc.
OriginalFileName =
ProductName = DVD Player
ProductVersion = 1, 0, 0, 30602
VBI Surface Allocator
FileDescription = VBI Surface Allocator Filter
InternalName = VBISURF.AX
OriginalFileName = VBISURF.AX
Video Port Manager
ProductName =
Windows Media Video Decoder
FileVersion = 8.0.0.4000
FileDescription = Windows Media Video Decoder V8
InternalName = wmv8ds32.ax
LegalCopyright = Copyright (C) Microsoft Corp. 1996-2001
OriginalFileName = wmv8ds32.ax
ProductName = Windows Media Video Decoder V8
ProductVersion = 8.0.0.4000
InternalName = wmvds32.ax
OriginalFileName = wmvds32.ax
WMV Screen decoder DMO
FileDescription = Windows Media Screen Decoder
InternalName = wmsdmod.dll
OriginalFileName = wmsdmod.dll
WMVideo Decoder DMO
FileDescription = Corona Windows Media Video Decoder
InternalName = wmvdmod.dll
OriginalFileName = wmvdmod.dll
WMVideo9 Encoder DMO
FileDescription = Corona Windows Media Video Encoder
InternalName = wmvdmoe2.dll
OriginalFileName = wmvdmoe2.dll
Audio Codecs
AC3Filter
FileVersion = 0.70b
CompanyName =
FileDescription = ac3filter
InternalName = ac3filter
LegalCopyright = Copyright © 2002 by Vigovsky Alexander
OriginalFileName = ac3filter.ax
ProductName = AC3Filter
ProductVersion = 0.70b
ACELP.net
FileVersion = 3.02
CompanyName = Sipro Lab Telecom Inc.
FileDescription = Audio codec for MS ACM
InternalName = sl_anet.acm
LegalCopyright = Copyright © Sipro Lab Telecom Inc. 1998-99
OriginalFileName = sl_anet.acm
ProductName = ACELP.net Audio Codec
ProductVersion = 3.02
ACELP.net Sipro Lab Audio Decoder
FileVersion = 1.40
FileDescription = ACELP.net Audio Decoder
InternalName = AcelpDec.ax
LegalCopyright = Copyright (C) 1997-99 Sipro Lab Telecom Inc.
OriginalFileName = AcelpDec.ax
ProductName = ACELP.net Audio Decoder
ProductVersion = 1.40
ACM Wrapper
ProductName =
C-Media Wave Device
InternalName = QCap.dll
OriginalFileName = QCap.dll
ProductName =
CCITT A-Law
FileDescription = Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM
InternalName = Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM
OriginalFileName = msg711.acm
CCITT u-Law
CoreAAC Audio Decoder
FileVersion = 1, 1, 0, 642
CompanyName =
FileDescription = CoreAAC
InternalName = CoreAAC
LegalCopyright = see the about box :p
OriginalFileName = CoreAAC.ax
ProductName =
ProductVersion = 1, 1, 0, 642
CoreFLAC Audio Decoder
FileVersion = 0, 4, 0, 46
CompanyName = -
FileDescription = CoreFLAC Audio Decoder & Source DirectShow Filter
InternalName = CoreFLACDecoder
LegalCopyright = Copyright © 2003-2004 Christophe Paris & Jory Stone
OriginalFileName = CoreFLAC.ax
ProductName = CoreFLACDecoder
ProductVersion = 0, 4, 0, 46
CoreVorbis Audio Decoder
FileVersion = 1, 1, 0, 79
CompanyName = -
FileDescription = CoreVorbis
InternalName = CoreVorbis
LegalCopyright = Copyright © 2004-2005
OriginalFileName = CoreVorbis.ax
ProductName = CoreVorbis
ProductVersion = 1, 1, 0, 79
CyberLink Audio Decoder
FileVersion = 5.00.0611
FileDescription = CyberLink Audio Decoder Filter
InternalName = CLAUD.AX
LegalCopyright = Copyright (c) CyberLink Corp. 1997-2003
OriginalFileName = CLAud.ax
ProductName = CyberLink Audio Decoder Filter
ProductVersion = 5.00.0611
DC-DSP Filter
FileVersion = 0, 9, 2, 0
CompanyName =
FileDescription = DirectShow™ Audio Transform Filter
InternalName = DCDSPFilter.ax
LegalCopyright = Copyright © 2003 Milenko "DCoder" Mitrovic
OriginalFileName = DCDSPFilter.ax
ProductName = DC-DSP Filter
ProductVersion = 0, 9, 2, 0
DC-DSP Filter (autoloading)
CompanyName =
DMO DolbyDecoder
FileVersion = 1.0
CompanyName = Adobe Systems Incorporated
FileDescription = Dolby Decoder
InternalName = Dolby Decoder DMO
LegalCopyright = Copyright (c) 2002-3 Adobe Systems Incorporated
OriginalFileName = dmoDolbyDecoder.dll
ProductName = DVD Encore
ProductVersion = 1.0
DSP Group TrueSpeech(TM)
FileVersion = 1.01
CompanyName = DSP GROUP, INC.
FileDescription = DSP Group TrueSpeech(TM) Audio Codec for MSACM V3.50
InternalName = tssoft32.acm
LegalCopyright = Copyright DSP Group, Inc. 1993-1996
OriginalFileName = tssoft32.acm
ProductName = DSP GROUP Windows NT(TM) TrueSpeech CODEC
ProductVersion = 1.01
DVD Express Audio Decoder
DVDExpress 3D (Aureal)
FileVersion = 5.01.010
CompanyName = Mediamatics, Inc.
FileDescription = 3D Virtualization support
InternalName = DVD Express 3D Sound.DLL
LegalCopyright = Copyright (C) 1995-2001 Mediamatics, Inc.
OriginalFileName = DVD Express 3D Sound.DLL
ProductVersion = 5.01.010
DVDExpress 3D (Dolby Headphone)
DVDExpress 3D (N-2-2)
DVDExpress 3D (NSC)
DVDExpress 3D (QSurround)
DVDExpress 3D (Sample)
DVDExpress 3D (VMAx)
ffdshow Audio Decoder
CompanyName =
GSM 6.10
FileDescription = Microsoft GSM 6.10 Audio CODEC for MSACM
InternalName = Microsoft GSM 6.10 Audio CODEC for MSACM
OriginalFileName = msgsm32.acm
htAudioTransFilter
FileVersion = 8.10
FileDescription = Special Effects Sample
InternalName = EzRgb24.ax
LegalCopyright = Copyright (C) 1992-2001 Microsoft Corporation
OriginalFileName = EzRgb24.ax
ProductName = DirectX 8.1 Sample
ProductVersion = 8.10
IAC2
FileVersion = 2.05.54
FileDescription = Indeo® Audio Software
InternalName = iac25_32.ax
LegalCopyright = © 1997 Intel Corp.; © 2000 Ligos Corp.
OriginalFileName = iac25_32.ax
ProductName = Indeo® Audio Software
ProductVersion = 2.05.54
IMA ADPCM
FileDescription = IMA ADPCM CODEC for MSACM
InternalName = IMA ADPCM CODEC for MSACM
OriginalFileName = imaadp32.acm
InterVideo Audio Decoder
FileVersion = 2.8.18.0
FileDescription = IVIAUDIO
InternalName = iviAudio.ax
LegalCopyright = Copyright © 1998, 1999 InterVideo Inc.
OriginalFileName = iviAudio.ax
ProductName = InterVideo Audio Decoder
ProductVersion = 2.8.18.0
MainConcept (AdobeEncore) MPEG Audio Encoder
FileVersion = 1, 0, 0, 9
FileDescription = MPEG Audio Encoder
InternalName = MCEAMPEG.DLL Adobe
LegalCopyright = Copyright (C) 2001-2003 MainConcept AG
OriginalFileName = MCEAMPEG.DLL Adobe
ProductName = MPEG Audio Encoder
ProductVersion = 1, 0, 0, 9
Microsoft ADPCM
FileDescription = Microsoft ADPCM CODEC for MSACM
InternalName = Microsoft ADPCM CODEC for MSACM
OriginalFileName = msadp32.acm
Microsoft G.723.1
FileVersion = 4.4.3400
FileDescription = Microsoft G.723.1 CODEC for MSACM
InternalName = msg723
OriginalFileName = msg723.acm
Modem #0 Line Record
ProductName =
Modem #2 Line Record
ProductName =
MPEG Audio Decoder
ProductName =
MPEG Layer-3
FileVersion = 1, 9, 0, 0305
CompanyName = Fraunhofer Institut Integrierte Schaltungen IIS
FileDescription = MPEG Layer-3 Audio Codec for MSACM
InternalName = l3codec.acm
LegalCopyright = Copyright © 1996-1999 Fraunhofer Institut Integrierte Schaltungen IIS
OriginalFileName = l3codec.acm
ProductName = MPEG Layer-3 Audio Codec for MSACM
ProductVersion = 1, 0, 0, 0
MPEG Layer-3 Decoder
FileVersion = 1, 5, 0, 50
FileDescription = MPEG Layer-3 Audio Decoder
InternalName = L3CODECX.AX
LegalCopyright = Copyright (C) 1997 Fraunhofer IIS
OriginalFileName = L3CODECX.AX
ProductName = MPEG Layer-3 Audio Codec for Microsoft DirectShow
ProductVersion = 1, 5, 0, 50
Nero Digital Audio Decoder
CompanyName = Ahead Software AG and its licensors
FileDescription = Nero Digital Audio Decoding Filter
InternalName =
LegalCopyright = Copyright (C) 2004 Ahead Software AG and its licensors
OriginalFileName = NeAudio.ax
ProductName =
ProductVersion = 1, 0, 4, 48
PCM
Ulead DVD Audio decoder
FileDescription = Audio Decoder
InternalName =
OriginalFileName =
ProductName = DVD Audio Decoder Filter
Vorbis Compressor
FileVersion = 0, 9, 9, 5
CompanyName =
FileDescription = Ogg DirectShow(tm) Filter Collection
InternalName = OggDS
LegalCopyright = Copyright (C) 2002 Tobias Waldvogel
OriginalFileName = OggDS.DLL
ProductName = Ogg DirectShow(tm) Filter Collection
ProductVersion = 0, 9, 9, 5
Vorbis Decoder
CompanyName =
Vorbis Encoder
CompanyName =
Windows Media Audio Decoder
FileDescription = Windows Media Audio Decoder
InternalName = msadds32.ax
LegalCopyright = Copyright (C) Microsoft Corp. 1999-2001
OriginalFileName = msadds32.ax
ProductName = Windows Media Audio Decoder
Windows Media Audio V1
InternalName = msaud32
OriginalFileName = msaud32
Windows Media Audio V2
WM Speech Encoder DMO
FileDescription = Windows Media Speech Encoder
InternalName = wmspdmoe.dll
OriginalFileName = wmspdmoe.dll
WMAudio Decoder DMO
FileDescription = Corona Windows Media Audio Decoder
InternalName = wmadmod.dll
OriginalFileName = wmadmod.dll
WMAudio Encoder DMO
FileDescription = Corona Windows Media Audio 9 Encoder/Transcoder
InternalName = wmadmoe2.dll
OriginalFileName = wmadmoe2.dll
WMSpeech Decoder DMO
FileDescription = Windows Media Speech Decoder
InternalName = wmspdmod.dll
OriginalFileName = wmspdmod.dll
Broken Codecs
[No codecs were found broken.]
10,487 (1.37/day)
Download gspot codec information and use it on the file that doesnt run correctly, it'll tell you what codecs are used.
Ralph_B
6 (0.00/day)
wmv files scrambled colours
gspot doesn't work for wmv files
I've since re-installed windows media player (v9) and the problem is resolved, I've alos been advised that installation of WMPv10 should have fixed the problem.
bigbadwolf284
94 (0.01/day)
new york
Processor amd 3200+@2.2
Motherboard biostar
Cooling all air....lol
Memory never enough.....
Video Card(s) 7600gt @600/820
Storage 160 GB sata
Display(s) 19 widedscreen acer lcd
Case thermaltake soprano
Audio Device(s) SB
Power Supply 500W ultra
Software XP PRO
2 words : Get VLC player
|GIA| GAB
1 (0.00/day)
I got the problem too, with wmv
In mediaplayer you can fix it
go to: tools-> options
click an the tab performance
by videoacceleration click advanced settings
by the renderer options change from 'use overlays' to 'high quality mode'
worked for me!
8,253 (1.17/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
