Movement problems with my Razor Deathadder Chroma mouse.
330 (0.05/day)
Emilia Romagna, Italy
Processor AMD Ryzen 5 1600
Motherboard Asus ROG Strix B350-F Gaming
Cooling AMD Wraith Spire, 4x Corsair SP120 RGB, GPU stock
Memory G-Skill Ripjaws V, 2400MHz, 15-15-15-35, 2 x 8GB (F4-2400C15D-16GVR)
Video Card(s) XFX RX580 8Gb Black Edition
Storage 1x Samsung 1TB 990 EVO Plus M.2 SSD, 1x Samsung 1TB 850 EVO SATA SSD
Display(s) 2x Viewsonic VX2780-2K
Case Corsair Crystal 460X RGB
Power Supply Corsair HX750
Mouse Razer Deathadder Chroma
Keyboard Corsair K70 RGB Mk.2
Software Windows 10 Home 64bit
In the past few weeks my Razor Deathadder has started acting up as soon as I turn the my computer on and begin using it; the cursor is staggered, jumpy, laggy in its movement. However, when I restart my computer it immediately goes and is back to normal and this is the case every time.
Just a few moments ago I updated the software and it's still doing it, right now!
I'll do a complete uninstall of the software and see if that makes a difference.
Any ideas?
Tom.
Try it on a different computer if you can and see if it does the same thing.
Could be a manufacturers error.
Last night I removed the Razer Synapse configuration software and I've turned the computer on twice today and no problems. I'll load Synapse back on and see if the problem happens again.
Blobster,
I did not. If it happens again, I'll have a look.
Tom.
Check for debris/hair on sensor.
The cable is good? Just to check
I had similar issues with my Naga 2014.
Here are things you should try if it happens again:
  1. Make sure your mouse pad is clean. Sometimes a very dark or dirty pad can cause taking issues
  2. Try the mouse in different USB ports
  3. Try the mouse on a different computer
  4. Try the mouse on a clean white sheet of printer paper
Ways I resolved the issue as it cropped up multiple times for me that makes zero sense to me as to why it resolved:
  • 1st time. Sheet of white printer paper. I used it for a couple of days and went back to my mouse pad and the issue was gone. The original mouse pad wasn't changed in any way, yet the tracking issue was gone after a couple of days.
  • 2nd time. Uninstalled synapse software and the issue went away.
  • 3rd time. Installed the synapse software and the tracking issue went away.
I had other issues with the mouse and the synapse software. Then, about 2 weeks after the 2 year warranty was up, the middle mouse button completely failed. Razor wouldn't replace it so I threw it out.
Not a single issue with my Logitech G502 in the past 3 years now.
