MSI 970 Gaming - PWM fan Problem
46 (0.01/day)
i buy this 2 days ago, everything was ok, but i've got one problem about PWM fan, smart fan control on BIOS is not work, when cpu idle/load, my cpu fan not go higher or lower, all i can do is set my pwm fan to speedup fan rpm manually (i prefer 1700rpm and it stay on 1700 rpm when idle or load state)
this is very annoying to brand new mobo like this, my CM seidon 120XL work perferctly in my old mobo, Gigabye 78LMT s2p. never had this issue Before.
i connect 2 pwm fan to CPU fan header Via Y splitter as before.
and pump to Sysfan1 (4 pin ) and try to swap this to other (3 Pin )
Result still same. fan speed, not going up /lower depend on CPU load.
Any help will be appreciated,
3,059 (0.43/day)
Baltimore MD
Processor Ryzen 5900X
Motherboard ASUS Prime X470 Pro
Cooling Arctic liquid freezer II 240
Memory 2 x 16 Gb Gskill Trident Z 3600 Mhz
Video Card(s) MSI Ventus 3060 Ti OC
Storage Samsung 960 EVO 500 Gb / 860 EVO 1 Tb
Display(s) Dell S2719DGF
Case Lian Li Lancool II Mesh
Mouse Logitech G703
Keyboard Logitech G513
Software Win 11
the smart fan control should have an option for control type, the options should be AUTO, VOLTAGE, PWM
Make sure you have it set to PWM as auto may not be working correctly
46 (0.01/day)
there is no "PWM" option as u describe in my bios... sadly. :(
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
motherboard bios up to date?
have target temprature setup
have min and max fan speed sliders equal [set 50/50 to test]
"Fan control field
This motherboard provides a fan speed control feature call “Smart Fan Control”.
Smart Fan Control automatically controls fan speed depending on the current CPU
temperature and to keep it with a specific operating speed. When the current CPU
temperature is over the maximum temperature, the CPU/ system fan will run at
the maximum speed. When the current CPU temperature is under the minimum
temperature, the CPU/ system fan will run at the minimum speed. In this field, you can
set the CPU and system fans’ speeds and target temperatures."
Source - here
atb
Law-II
46 (0.01/day)
No bios update yet.
yes i have, 50 degree targeted temp
yes i do that before.
i tried everything before.
