After Gigabyte and ASUS, it appears that MSI is also working on a similar motherboard concept that puts most, if not all, connectors on the reverse side of the motherboard. MSI will be joining Gigabyte, ASUS and MaxSun with such concept, as MSI B650 DIY-APE motherboard has been now spotted online. In order to optimize cable management, the idea is that most, if not all connectors are located on the reverse side of the motherboard, allowing users to hide power, fan, storage, and peripherals cables behind the motherboard.
According to the latest leak, MSI is apparently working on two motherboards based on AMD B650 chipset that have entered a qualification state. While it means that these are still far away from being a retail product, it is certainly an interesting concept that we are looking forward to. Of course, this also means that one would need a compatible PC case, that has strategically placed cutouts in order to access those connectors. The original post has some of those cases pictured. In addition to ASUS, MaxSun, and now MSI, Gigabyte also had a similar concept with Project Stealth.
