msi b350 tomahawk pcie running at 8x only
Mckinney405
7 (0.00/day)
Hey guys in I just got my new msi motherboard and got it all running and checked gpu z and my gtx 980 ti is only running at 8x instead of 16x. Even in the bios its 8x. I tried benches and the render test. I'm getting around 10 less frames when gaming. I'm going to return this back to amazon tomorrow if I can't get this fixed. Thanks in advanced
Specs
Msi b350 tomahawk
Ryzen r5 1600
Corsair lpx 3000
Gigabyte G1 gtx 980 ti
Eva 700w psu 80+ bronze
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
Is your video card the only thing you have plugged in to the motherboards PCI lanes?
Please upload a screenshot of the current version of GPU Z with the main window showing the pci speed
Also it running at 8x isn't going to affect your frame rate .I'm certain that card (or any other) isn't going to saturate at that speed
Also make sure in your bios you set it to PCI three it most likely has the option to change between one two& three or something similar
tested with a GTX1080
Also tpu did a test too. Any fps drop you feel is occurring is not because of x8 pcie.
https://www.google.com/amp/s/www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_1080_PCI_Express_Scaling/?amp
Mckinney405
7 (0.00/day)
It is the only card in any of the lanes.
The gpuz is the latest from the website. Fresh install of windows 10 64
Mckinney405
7 (0.00/day)
No options to set pcie gen or anything pci e in the bios ive tried every bios on msi website
Ruru
S.T.A.R.S.
13,779 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
7,490 (1.04/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
If u don't have a extra card plugged into any of the other PCI-E/PCI slots u could try to re-seat ur GTX 980 Ti and CPU and see if that fixes ur issue if not and it bothers u get in contact with MSI support mby they will just advise you to RMA the board.
540 (0.17/day)
System Name Gaming PC / I7 XEON
Processor I7 4790K @stock / XEON W3680 @ stock
Motherboard Asus Z97 MAXIMUS VII FORMULA / GIGABYTE X58 UD7
Cooling X61 Kraken / X61 Kraken
Memory 32gb Vengeance 2133 Mhz / 24b Corsair XMS3 1600 Mhz
Video Card(s) Gainward GLH 1080 / MSI Gaming X Radeon RX480 8 GB
Storage Samsung EVO 850 500gb ,3 tb seagate, 2 samsung 1tb in raid 0 / Kingdian 240 gb, megaraid SAS 9341-8
Display(s) 2 BENQ 27" GL2706PQ / Dell UP2716D LCD Monitor 27 "
Case Corsair Graphite Series 780T / Corsair Obsidian 750 D
Audio Device(s) ON BOARD / ON BOARD
Power Supply Sapphire Pure 950w / Corsair RMI 750w
Mouse Steelseries Sesnsei / Steelseries Sensei raw
Keyboard Razer BlackWidow Chroma / Razer BlackWidow Chroma
Software Windows 1064bit PRO / Windows 1064bit PRO
gpu-z is not the bible maybe there is an issue with it. Check with other program. and as said by others didnt change your framerate at all.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Can you seat the card in the lower Lane and see what it says? i dont see why the MoBo wouldnt report correctly....id open a support ticket with MSI. i wonder if since everything is so new, do You mind resetting the bios to "default"/Clear CMOS ? maybe a option got switched on accident?
pretty nice that Your bios is that interactive. my isnt :(
also i noticed some CPU dependant speeds when reading over the SPecs on that board.... id definitely reach out to the Maker... i have VERy little exp with AMD chips, and theyre issues, so im going to bow out....but im sure You'll find help with the issue.
make sure you have the most recent bios too for your MoBo. I don't know from experience but I do know that I've heard in the recent past about issues with ryzen chips requiring bios updates for compatibility or something
Mckinney405
7 (0.00/day)
Returning it today to amazon. Getting a gigabyte b350 hd3
I tried everything under the sun
18,452 (2.47/day)
Some PCIe cards go down to x8 lane with when there isn't enough load on the card. Try loading up something 3D and see if it doesn't change to x16.
As you can see, my card goes down to x16, but PCIe 1.1 rather than 3.0, but the slot is not PCIe 1.1.
As soon as I fired up Battlenet (I refuse to use the new name), it went straight to PCIe 3.0.
44,274 (6.80/day)
Read your manuals, breadboard the system before putting in a case
Toothless
Tech, Games, and TPU!
9,815 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Guys he already returned it.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Yeah he says that hes already arranged the return.
Aside from there being a x16 on pci-e readings instead of an x8, there wont be any difference. It's been tested with far more capable pc's than op's, and no negligable difference was found between the two. But its his dime, if it makes op feel better than more power to him(he Did pay for a board that advertised it).
maybe they have some Case stickers they could send with the new Board....it Should provide better gaming performance in highly demanding titles.(im getting some)
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I've only ever seen a select few cards do this, but most do not. And the only ones that I've seen do it are secondary cards in Crossfire.
They'll go down to 1.1, but not lower the number of PCI-e lanes.
14,546 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Mckinney405
7 (0.00/day)
Gpu still running at x8. My first ryzen mobo was fine running at 16x which was a asrock. But the bios failed and had to rma it.
Any ideas? I updated to the newest bios.and changed it to gen 3 and same
14,546 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Check the gold fingers on the base of the card for damage.
Mckinney405
7 (0.00/day)
Just checked looks good. After this thunderstorm passes I'm going to see about updating the bios on the card. Unless there is a better way
167 (0.02/day)
System Name BlackLightening
Processor AMD Ryzen 9 7900X
Motherboard Gigabyte B650 Aorus Elite AX v2.0
Cooling Corsair H170i Pro Push/ Pull with 6 corsair SP 140's
Memory Corsair Vengeance Black RGB 32GB DDR5 6000MHz (2 x 16GB)
Video Card(s) EVGA GeForce RTX 3080 Ti FTW3 Ultra
Storage 1 - Samsung 980 Pro 1 TB PCIe 4.0 NVMe M.2 SSD, 2 -WD Black SN850X 2 TB PCIe 4.0 NVMe M.2 SSD,s
Display(s) MSI Optix MAG321CQR Curved
Case Corsair iCue 7000X RGB Full Tower Tempered Glass
Audio Device(s) Creative SoundBlaster X AE-5+ Pci-e (Logitech Z5300e speakers)
Power Supply Corsair HX 1000i
Mouse Corsair M65 Elite
Keyboard Corsair K68
Software Windows 11 Professional 64 bit
In your GPU-Z beside the Bus Interface click on the ?. It gives some explanation. Then click on the Start render test button and see if it increases.
Ruru
S.T.A.R.S.
13,779 (3.05/day)
Jyväskylä, Finland
Like I said, don't stress about that. PCI-E 3.0 X8 is about the same as PCI-E 2.0 X16, the performance hit is so small that it can't even be seen by normal gaming.
