MSI B450 Tomahawk MAX PWM fan speed up time
286 (0.08/day)
Hungary
Processor AMD Ryzen R7 5700X
Cooling Alpenföhn Dolomit Premium
Memory Kingston Fury Beast 16 GB
Video Card(s) Asus RTX 4070 Dual OC 12 GB
Storage Kingston Fury Renegade 1 TB, Western Digital Red 2 TB
Display(s) Dell G2724D
Case Fractal Design Meshify 2 Compact
Audio Device(s) Asus Xonar DSX + Microlab B-77
Power Supply Seasonic Focus GX-550
Mouse Zowie ZA11
Keyboard Endorfy Thock TKL Brown
Hi guys,
I've just bought a set of be quiet! Pure Wings 2 PWM fans and I've already set custom curves for them, but since Ryzen CPUs tend to have 10+ °C temp spikes every couple of minutes, I've been having all my fans speed up for ~5 seconds and then slow back down, which is really annoying. I have an MSI B450 Tomahawk MAX motherboard with the latest stable BIOS, and the only fan speed up delay options are 0.1s, 0.2s, 0.3s and 0.7s. Is there any option or workaround to set these delays around 2-3-5 seconds instead of these fractions?
Thanks!
I use this when BIOS has no fan curve options.
You can set fan curves, response times and hysteresis etc. tho I think you should disable fan curve in the BIOS if you use this software, temporarily at least, just so the settings do not interfere with each other.
Can you set the hysteresis in the BIOS higher?
Thanks, I'll give it a try.
There's no such option unfortunately.
