MSI B760 GAMING PLUS WIFI Motherboard CPU Overclocking Problem
11 (0.07/day)
Türkiye
System Name 53R
Processor Intel(R) Core(TM) i5-12600KF
Motherboard MSI B760 Gaming Plus WiFi
Cooling Cooler Master MasterLiquid Ml360R Rgb
Memory Patriot Viper Venom 32GB (2x16GB) DDR5 6400MHz CL32 Gaming Ram
Video Card(s) AMD Radeon RX 6700 XT
Storage Western Digital WD Blue SN580 NVMe (500 GB)
Display(s) HP X32 (2V7V4E9) 31.5 inç 1ms (HDMIDisplay) QHD 165 Hz FreeSync Premium IPS Gaming Monitör
Case Thermaltake Core P5
Audio Device(s) Realtek® ALC897 Codec 7.1-Channel High Definition Audio Supports S/PDIF Output
Power Supply THERMALTAKE Toughpower GF2 750W 80+ GOLD
Mouse Razer Deathadder Essential Gaming Mouse
Keyboard A4Tech Bloody S98 FIRE BLACK Hot Swappable Wired RGB Mechanical Gaming Keyboard
MSI B760 GAMING PLUS WIFI is on the motherboard. The CPU Overclock section in BIOS is disabled. Is there a way to enable this?
Mainboard Link
Well let's unbury the new guy's thread and give him an answer shall we??? (Sorry for delays)
The B760 Morter Max is the only MSI B series board I am aware of with an external clock generator that will overclock the reference clock or bus clock of the CPU. Only certain B600 series boards have the external clock generator also.
13th and 14th Gen Bioses are patched to prevent overclocking bus frequency. And obviously Z series boards are required to overclock via the cpu multiplier.
TLDR - No. There is no way to enable this.
Well, there are some videos on the internet. In these videos, the guys open CPU Xap with some settings. Is this possible?
Can you link the video/s please?
To recap - The external clock generator is an actual physical chip on the mainboard. Your board does not have one.
So even if you "unlocked" bios OC settings, it wouldn't do anything.
