Hello forum members,
Recently upgraded my gpu to 980m on my laptop ( msi gt60 0nd), was able to install drivers via have cd method. Updated windows 10 to 1903. Have geforce experiance and controll. But games still lag, fps jumps 10-60 in games like overwach and csgo. Updated bios to 51x. Still nothing. Any advice?
You have no "bottleneck" on those games with that configuration. Lets get over the facts first:
1. On the official website your laptop CPU specifications are as follows "
3rd generation Intel® Core i7/i5 Processor"
2. Counter-Strike: Global Offensive System Requirements (Minimum) are "
CPU: Intel® Core™ 2 Duo E6600" and "DX9 compatible GPU"
3. Overwatch System Requirements (Minimum) are "
CPU: Intel Core i3 or AMD Phenom X3 8650" and "Nvidia GeForce GTX 460"
4. Install a fresh copy of Windows 10 1607 64-bit. That is the best version. Newer versions have fake performance degradation introduced to anyone running on any CPU older than 2019.
5. You should not have any problems if you install Windows 7 or Windows 10 1607. I do not understand why do you "
need" Windows 10 on
that configuration, to be exact.
6. Power consumption of your
GTX 980M is 100 Watt.
7. Power consumption of your previous
GTX 675M is also 100 watt.
8. Conclusion: There is no power supply "bottleneck" and there is no "CPU bottleneck". "Bottleneck" depends primarily on what games you play and is manifested in the game not the hardware itself. GPUs are designed to work with a multitude of CPUs. There is no such thing as compatibility issues between a CPU and GPU. It all depends on how the game is built.
Therefore, your issue may be in: either those games have bad code, or there is overheating in your motherboard or CPU. A good thing would be to use HWINFO (32 or 64 does not matter), and use it to record the sensor status in the range of 1 hour of gameplay to see what components of your laptop work on what temperatures. We shall see else, after that. Good luck!
