- Nov 11, 2004
- 18,484 (2.47/day)
- Sweden
Keyboard | Corsair K70 Max |
Software | Windows 10 Pro |
MSI IPC, a global leader in industrial computing solutions, proudly unveils the MS-CF05, V2.0, a high-performance ATX motherboard engineered for industrial automation, edge computing, and embedded applications. Designed to support 14th, 13th, and 12th Gen Intel Core, Pentium, and Celeron processors, the MS-CF05, V2.0 delivers exceptional computing power, scalability, and I/O flexibility, including a PCI slot for legacy support, making it ideal for modern industrial needs.
Key Features of MS-CF05, V2.0:
Optimized for Industrial Applications: The MS-CF05, V2.0 is engineered for high performance and reliability in industrial environments, supporting industrial automation, edge computing, and AI inference. It excels in handling real-time AI model inference and data processing, enabling businesses to make data-driven decisions without relying on the cloud. Additionally, its integration with IoT devices enhances monitoring and predictive capabilities across connected systems.
The motherboard's legacy PCI slot offers compatibility with older industrial peripherals, providing businesses with an easy upgrade path while retaining support for existing equipment. Designed with industrial-grade components, it operates reliably in harsh conditions, including wide temperature ranges, vibrations, and shocks, making it ideal for challenging environments.
Ideal Applications:
Availability & More Information MSI IPC will showcase the MS-CF05, V2.0 at Embedded World 2025, Booth No. 1-389, Nuremberg, Germany.
- Powerful Intel CPU Support: Supports 14th, 13th, and 12th Gen Intel processors with Intel Q670E chipsets for superior computing performance.
- High-Speed Memory: Four DDR5 4400 MT/s ECC/non-ECC UDIMM slots, supporting up to 128 GB for maximum efficiency in data processing applications.
- Triple Independent Displays: VGA, DisplayPort, and HDMI for flexible multi-display configurations.
- Advanced Networking Capabilities: Four 2.5GbE LAN ports with RJ-45 for high-speed data transmission and network redundancy.
- Flexible Expansion Options:
- 1 PCIe x16 (Gen 5) or 2 PCIe x8 (Gen 5) slots for GPUs and accelerators.
- 1 PCIe x4 (Gen 4), 3 PCIe x4 (Gen 3), and 1 PCI slot for legacy device compatibility.
- 1 M.2 B-key, 2 M.2 M-key slots, and 4 SATA 3.0 for versatile storage options.
- SATA RAID 0/1/5/10 support for data redundancy.
- Comprehensive Connectivity:
- 8 USB 3.2 Gen 2, 2 USB 3.2 Gen 1, and 3 USB 2.0 ports.
- 2 COM ports (RS-232/422/485), 4 COM ports (RS-232), GPIO, PS/2, and Audio support.
- 3 System FAN connectors for enhanced thermal management.
- Enhanced Security and Management: Onboard TPM 2.0, SMBus, I2C, PMBus, iAMT 16.x, and chassis intrusion detection.
- Reliable Power Design: ATX power supply for stable and efficient system operation.
Ideal Applications:
- Manufacturing Automation: IoT sensors, robots, and machine vision systems in production lines.
- Smart Cities: Data collection from smart devices and traffic management systems.
- Healthcare: Integration with medical equipment for remote monitoring.
- Energy & Utilities: Monitoring smart grids and renewable energy installations.
- Transportation & Logistics: Fleet management, predictive maintenance, and traffic monitoring.
