msi Rx 470 mining gpu, bios issue need correct bios
MdXd
3 (0.01/day)
hello
i recently got my hands on a rx470. I cannot play games with patched amd drivers there are flickering ingame. I'm assuming it has a mining bios. I've tried most bios files from techpowerup none is working. I've seen @eidairaman1 who has helped many people with bios issue. Please, if anyone can help me find bios, I'll be thankful.
s/n 602-V341-152SB1706027336
This BIOS matches your clock speeds, ID's and your RAM. And use version 2.93 of atiflash.
Tried it before and tried it again did not work.
The system does not POST
I assume you have a backup of the mining bios before you stared flashing. Can you share that bios with us?
I dont think 113-MSITV341MH.2M0 is the orginal bios for you card.
It seems 113-MSITV341MH.433 is the latest bios since the serial number is almost the same as some other people on the MSI forum. Sources:
https://forum-en.msi.com/index.php?threads/original-bios.331085/
https://forum-en.msi.com/index.php?...470-request-new-stock-bios-s-n-number.329806/
TV341MH.433 Bios:
https://forum-en.msi.com/index.php?attachments/tv341mh_433-rar.132648/
Here it is. Also, I've tried that BIOS as well from the MSI website.
113-MSITV341MH.433 is the latest bios for your card based on the serial number you have provided.
I've compared your bios backup with the bios suggested by pavle. Its almost the same bios. Only 7 bytes are different between those files.
1 byte belongs to the checksum, 6 bytes are modified at the memory controlling part of the bios.
Since you need to use the AMD/ATI Pixel Clock Patcher, the card is not working as designed.
If you got the card for free, throw it away. Did you pay for it, demand a refund from the seller!
