- Nov 11, 2004
- 18,538 (2.48/day)
- Sweden
Keyboard | Corsair K70 Max |
Software | Windows 10 Pro |
MSI, a global leader in industrial computing solutions, proudly announces the release of the MS-C927, a highly compact and fanless embedded Box PC designed to meet the growing demand for power-efficient edge computing in harsh and space-constrained environments. Powered by Intel 's Meteor Lake-U and Arrow Lake-U series Core Ultra processors, the MS-C927 delivers high performance, reliable connectivity, AI acceleration, and rich I/O in an ultra-compact form factor.
Feature-Rich, Future-Ready
With a footprint of only 130 x 155 x 40 mm, the MS-C927 fits seamlessly into tight enclosures while offering exceptional processing power and industrial-grade durability. It features DDR5 memory up to 96 GB, dual 4K DisplayPort outputs, dual LAN including 2.5GbE, and multiple M.2 slots for NVMe storage, wireless connectivity, and cellular communication.
Key Features:
Optimized for AI at the Edge
With Arrow Lake-U's hybrid architecture, the MS-C927 is engineered for next-gen AI-driven industrial and commercial edge applications. Ideal for object detection, facial recognition, visual inspection, and edge automation.
Versatile Applications Across Industries
The MS-C927 is tailor-made for embedded and industrial edge applications where rugged design, I/O flexibility, and 24/7 reliability are essential:
Industrial Automation & Machine Vision
Supports factory automation, vision inspection, and HMI terminals
Fast I/O and DDR5 ensure rapid response and high-resolution image processing
Fanless for cleanroom or dusty industrial environments
Smart Transportation & Fleet Systems
Vibration- and shock-proof (IEC 61373 compliant), ideal for railway, bus, or fleet installations
Wide voltage range and temperature support enable stable operation in mobile or roadside enclosures
M.2 slots allow integration of AI video analysis modules
AI at the Edge / Surveillance
NPU acceleration for smart city and security tasks such as object detection, license plate recognition, and behavioral analysis
Compact and rugged enough for pole or kiosk installation
Dual LAN and TPM make it secure and deployable in public or unattended systems
Retail, Self-Service & Kiosks
Dual 4K display outputs support digital signage and interactive kiosks
USB and COM ports enable peripheral control (touchscreens, printers, card readers)
Compact and silent for placement in front-facing retail environments
Medical & Laboratory Equipment
Silent fanless design suitable for clean and noise-sensitive settings
Reliable processing of imaging or data from diagnostic devices
TPM 2.0 ensures patient data protection and system integrity
Global Compliance & OS Support
With certifications for CE, FCC, RCM, BSMI, UKCA, VCCI, and support for Windows 10/11 IoT Enterprise LTSC and Linux (on request), the MS-C927 is ready for global deployment in critical environments.
Key Features:
- Intel Meteor Lake-U / Arrow Lake-U Core Ultra processors
- Dual DDR5 SO-DIMM slots, up to 96 GB (ARL-U up to 6400 MHz)
- 2x DisplayPort (4096 x 2304 @ 60 Hz)for independent 4K displays
- 1x 2.5GbE + 1x GbE LAN, powered by Intel I226-V and I219-LM
- 4x USB 10 Gbps, 2x COM ports, and 8-bit GPIO (4 GPI, 4 GPO)
- Triple M.2 expansion:
- M-key for NVMe
- B-key for Expansion card
- E-key for Wi-Fi/BT
- Fanless, wide-temp design (-10°C to 60°C) for challenging deployments
- Wide voltage DC-in (12-24 V) with OVP/OCP, and IEC 61373 shock/vibration compliance
- TPM 2.0 onboard for hardware-level security
