MSI z270 Tomahawk and i7-7700k - memory overclocking
trickle_38
4 (0.00/day)
Europe/Poland
Hi guys,
wanted to speed up a little my old computer. Memory I have is CORSAIR Vengeance LPX CMK16GX4M2B3000C15 SO IT IS DDR4-3000 (1500 MHz), and MSI says in manual that H270 can use :
Z270 chipset + 7th Gen processors support DDR4
3800(OC)/ 3600(OC)/ 3200(OC)/ 3000(OC)/ 2800(OC)/ 2600(OC)/ 2400/ 2133 MHz* but in BIOS the max. memory speed is 2400 ( that I am using now ) but wanted to go to 3000 MHz).
What to do in BIOS to have that memory working with 3000 MHz?
any suggestions?
Thanks in advance
Rob
ir_cow
5,014 (0.82/day)
USA
3000 MHz is 6000 MT/s (DDR4-6000). I know you mean DDR4-3000, but it will save you some headache knowing that DDR = double data rate. The MB say it can do is 1900 MHz (DDR4-3800). Still unlikely for the CPU.
For that DDR4-3000 kit to work all you need to do is enable XMP.
trickle_38
4 (0.00/day)
Europe/Poland
XMP is enabled in BIOS....
and in BIOS I can't go higher than 2400
ir_cow
5,014 (0.82/day)
USA
is XMP is enabled, than you are running DDR4-3000. Nothing left to do. 2400 MHz would be DDR4-4800. Impossible on that CPU.
trickle_38
4 (0.00/day)
Europe/Poland
is XMP is enabled, tand I am running memory DDR4-2400 and can't choose higher that DDR4-2400. my not proper wording. Target is to run DDR4-3000 at 1500Mhz
Deleted member 185158
Z270 should OC past 2400mhz. The board may just need a bios update. Do the update after you clear cmos.
2,451 (1.17/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
ive got a z270f asus motherboard with i7 6700k, it ran 4x8 3200mhz kit i threw at it with xmp profile enabled and it should run your 3000mhz kit no probs
but your first post you stated you have a h270 or z270
354 (0.09/day)
Oztralia down under
System Name K9
Processor i9 9900K @ 5.1Ghz and 32deg C - delid + Grizzly Conductonaught LM
Motherboard Gigabyte Aorus Z390 Gaming X
Cooling Custom water cooling loop - GPU + mobo (+VRM's) + CPU
Memory G Skill - Trident Z RGB DDR4 - 3866Mhz x 32Gb @ 3800Mhz
Video Card(s) Gigabyte Aorus 11Gb GTX 1080 Ti Waterforce Extreme @ 2250Mhz
Storage Samsung 500Gb M2 970 EVO + Samsung 850 Pro SSD + ADATA 512Gb SSD + Samsung 1Tb & 3T + WD 1Tb + 3Tb
Display(s) ASUS 27" ROG Swift 1440p @ 165Hz & BenQ 27" LED
Case Thermaltake Core P7 - Open frame
Audio Device(s) Logitech Z906 - 5.1ch
Power Supply EVGA 1200W
Mouse Roccat LeadR + Razer Nagar V2 Pro
Keyboard Corsair K70 LUX with Cherry Red switches
Software Win 10 Pro 64bit
Benchmark Scores v/fast
hi trickle_38,
I had a Gigabyte GA-Z270X Gamming mobo, i7-7700K, with Gskill TridentZ RGB DDR3866 memory installed.
It WAS a nightmare to OC the memory. I tried for around 6 months using the XMP profiles before giving up.
I ended up disabling the XMP and did the OC manually in the Advanced memory settings, to get it stable @ 4200.
BTW: the i7 was delided with Grizzly liquid metal and under water cooling.
There are a lot of good OC guides on the web.
Good luck
trickle_38
4 (0.00/day)
Europe/Poland
right H270
