Mw2 mp crash?!
2,076 (0.36/day)
System Name Omen
Processor i7-4710HQ
Cooling Dual fan/heatpipe
Memory 16GB
Video Card(s) 4GB GTX 860M
Storage 256GB PCIE SSD/256GB PNY UHS-1 SD Card
Display(s) 15.6' 1080P
Case Aluminium
Power Supply Brick
Software Win 10
I'm sick and tired of this. Mw2 multiplayer crashes during gameplay/loading screens. I might get a solid 30 mins of play then bang! The windows ding sound showing error. Or sometimes i might just load the first map, then BANG it crashes. The only weird thing is that IT ONLY HAPPENS ON MULTIPLAYER, the sp works fine no worries!
Temps are fine 55c at load for gpu, 48c for load for cpu. I even took my oc off, no fix. On a few odd occasions it says DirectX has encountered a problem. but it only happens with multiplayer. I'm very tired of this. I also have the newest drivers 260.99, i've even tried using 1 and two cards! it still happens with the usual three. I'm sick and tired of this, could anyone think of the problem. This is the only game this occurs cod 4 is fine, bfbc2 is fine! Please help :D
Bump,
no one can help? :(
Ok, i found the error it says something about create2d88924738%43 etc has ran out of memory...? Thought its strange as this only occurs with the multiplayer.. :S
4Gb should be good, I would do as erocker suggested and update directx or install the directx from the game disc. That's done the trick for a few games on my end, you may have the newest directx but if the game is looking for a file that was changed you'll get crashes. What size pagefile are you using? Sometimes you may find it best to set manually and have both fields the same size.
thats very weird, its not like mw2 can use 1gb of vram at 1360x768.so if i set it to automatic it should fixit. but yet this problem never occurs with singleplayer. even gta4 doesn't go over my cards 1gb v ram!
I had the same error Direct X has encountered unrecoverable error set graphics to Automatic and it fixes the issue Rideout421 on Steam as well
