Thestalost
- Mar 19, 2020
- 1 (0.00/day)
My computer started having some problems, by randomly showding down. After working at it a little, it finally decided it had enough and stopped working completly. At this point, it was either the Mother Board or the Power Supply, as neither cooler was working.
I've decieed to go with the Power Supply, because is cheaper and it is harder for the mother board to break down. But after getting a new Power Supply it continued to not work.
After leaving the PC, without even touching it, I decided to see if it works. Than suddenly it started booting. The coolers started working, and after a few second the long beep that there are no errors was heard, but it still wouldn't start. Then the very next try it started without any problems, and now it worked perfectly.
After the day was over, I shout it down, I went to sleep and in the morning it doesn't work again, as if the Power Supply was broken. The only reason I see is either the On/Off Button or the Mother Board. Some ideas on your side?
