My Computer Is Having Random Ping Spikes Up To 3000. Please Help.
3 (0.00/day)
Hello all, okay let me start this by saying that this has been an issue for almost a year now. I've been able to deal with it and suck it up for this long but I've finally cracked. I can honestly feel the hairs being ripped from my scalp as we speak... Okay let me explain my issue.
When I first made my computer I was sure that I had to go wireless adapter right off the bat. Mainly because my room is on the other side of the house compared too where the router is. And all was good, so I had a very crisp 20-25ms solid nearly no problems at all. Plus our neighborhood just got the google fiber upgrades that it so badly needed. About more than a year goes by and I start having these very weird ping spikes that would for no reason at all shoot up to about 1000-3000ms. This would happen about every few minutes but sometimes it can vary. It'd halt everything I was doing at the time, most of it being talking to friends over discord and playing games. This would either give me a few good seconds of me flying through random objects in the game I was playing or just completely disconnect me from it. I've been doing a lot of researching over the year and trying to figure this out little by little to hopefully find a solution to fixing this. But believe me I am no Tech Wizard.
In total we have about 4 or so computers along with maybe 4 more phones in the house who are connected to the internet. I've gone and compared this to the other devices in the house and none except my desktop are experiencing this. I ended up buying another adapter to see if it was a adapter issue but I'd still give me the same problem. I checked to see if this was a hardware problem, as far as I can tell it's not. I took my computer back down stairs and connected it to the router (in the living room) via Ethernet and had zero problems with it. I brought it back upstairs because I'd have no privacy and its impossible for me to have a set up down there.
I've done quite a lot of things like console commands and router changes in some of my options. After seeing what other people are experiencing and trying to compare it to mine, but I think it was about time for me to post my own thread because I think what this is could be very unique.
d7d1dbeedbcb593550c9d87c2cd4b8a2.png2d8765716c468f4c949a7dbda290744b.png This is me pinging google.com
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
what about moving your pc somewhere and test it again, what about the gain and how many bars that you have in your pc?
if the result is the same i guess it's from wireless itself and there's nothing you can do
13,952 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
What does Speedtest.net show?
Try pinging your ISP instead of Google. If those ping times are good, then I would use tracert -4 www.google.com to see if you can determine where the high latency is happening. If pinging your ISP are bad, contact your ISP.
I also agree with micropage7. You should try pinging with a computer direct connected to your router via Ethernet. If latency issues are encountered there too, then troubleshooting from your distant room via wireless is pointless.
207 (0.09/day)
Processor 3700x @ 4.3
Motherboard Crosshair 7 hero
Cooling Kraken X62
Memory 16GB Trident-Z 3200
Video Card(s) EVGA RTX2080 XC Ultra
Storage Samsung 960 evo 500gb NVME
Display(s) ASUS ROG Swift PG348Q
Case NZXT H500
Audio Device(s) Phillips SHP 9500s.....Audio Technica AT 2035 microphone.....Scarlett 2i2 audio interface.
Power Supply EVGA 850W Supernova G2
Mouse Model O
Keyboard Corsair K65
I have recently been getting a lot of Packet loss thru Comcast, this causes severe lag even though my ping in game (rocket league) stays decent. Sometime Pinging Youtube or Google will result in occasional 2,000 ms pings and tracert will result in timed out servers along the hop. It has gotten much better over the past couple days though.
3 (0.00/day)
I appreciate the help. I did some tracert stuff to see where I'm getting my high ping from and I think I need to call my provider and see whats going on on there end.
13,952 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Keep us posted.
Check your cables too - especially if a separate router and modem. Those factory made Ethernet cables typically are cheaply made, often poorly crimped. Yet they are critical network devices. Check the cable from the ISP to the gateway device (typically the modem) too.
74 (0.02/day)
Quebec City
System Name Orion
Processor Intel I7 3770K Ivy Bridge @4.6GHz
Motherboard Asus Sabertooth Z77
Cooling Corsair H100i
Memory 16GB Corsair Vengeance Dual/Quad Channel DDR3 CMZ16GX3M4A1600C9
Video Card(s) EVGA 780Ti Superclocked 3GB (OC +130MHz/248MHz)
Storage 1x 240GB Kingston Hyper-X 3K, 3x 3TB Seagate ST3000DM001
Display(s) Sony Bravia 55" KDL-55HX800 / Oculus DK1 / Oculus DK2
Case CoolerMaster HAX
Audio Device(s) OnBoard
Power Supply CoolerMaster Silent Pro M2 850W
Benchmark Scores UniEngine Valley 1.0 : 5539 3dMark Firestrike: 11468
If we start from the fact that you have no problem when you are physically connected, we can safely assume that this is probably a wireless connection problem.
You could start with continuously pinging your gateway (ping -t yourGatewayIP) from different spots in your house while connected via wi-fi to see if some areas are more problematic than others. Try to log 30 mins worth of pings at each spot. If you notice some areas are free of problems, you definitely have some sort of RF issue.
You also have to check for ping each test if your wireless adapter connects to the 2.4Ghz band, or the 5Ghz band. The 2.4Ghz band is more prone to channel saturation and cochannel interference, but it has much better range. On the other hand, 5Ghz has alot more channels and so it drastically diminishes co-channel interference problems, but its range is not as good as 2.4Ghz.
If you notice your problems mostly happen on one band you can usually force your adapter on the other band via the driver's settings. It can be a pain to find them if you're not tech savvy though... but they are there.
Ideally, you should do a 30min test run for each band in each spot. It's alot of work, but this is the drawback of troubleshooting wi-fi.
I would start with this without going any deeper.
bug
14,339 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Also, just stating the obvious, but use a network analyzer and try to set your router to use a channel with as few interference as possible.
But this may not be able to solve your problem if you have a rogue device in your house that will simply migrate to the same channel.
