My HDMI display can't accept a display which works at 720x720...at this resolution my console and desktop flickers and go round and round...
232 (0.14/day)
Hello.
I'm working on the creation of a FreeBSD based smartphone.
I've installed FreeBSD 14.3-Stable on my Radxa-3W. It works well on my HDMI big monitor that I keep at 1920x1080 of resolution,but it goes round and round like a carousel on my 720x720 display (to show you I have attached a small recorded video) , this one :
https://www.waveshare.com/4inch-hdmi-lcd-c.htm
I've grabbed two log files that I have attached.
The log called "log-big-monitor" comes from the monitor that I'm using right now at 1920x1080 resolution connected to the RadXA 3w via HDMI.
The log called "log-720 x 720-display" comes from the 4x4 inches display that I've bought to use with the smartphone that I want to create.
You will see that it thinks that the display is 1280x720 (720p) and that is wrong and will likely cause the display to not understand what it gets delivered…
Someone can tweak EDK2 to let me use my display at 720x720 resolution ? Please,I don't have the skills to understand what parameters to change inside the code here :
Furthermore,can you suggest to me a place where I can hire a developer that can give a look inside the code if something can be done to fix the error ? I can pay him / her a reasonable price for the job to do. Maybe it is an easy task.
Thanks.
