audiotranceable
- Aug 31, 2009
- 350 (0.06/day)
- Westminster, B.C
System Name | Asus G60vx |
Processor | Intel P7450 @ 2.666 MHz (setfsb) |
Motherboard | Intel PM45 Rev 07 + ICH9-M Rev 03 |
Cooling | Stock |
Memory | Hyundai DDR2 800 @ 1000mhz |
Video Card(s) | Nvidia GTX260 1024MB 256-bit |
Storage | 250GB SATA 2 (5400rpm) *time to upgrade* |
Display(s) | 1366x768 @ 90hz |
Case | Stock |
Audio Device(s) | Realtek HD |
Power Supply | Stock |
Software | Windows 7 SP1 64-bit |
All I gotta say is What the F***. I want to address couple issues I'm having.
1st. The game won't even start at all unless you have it running under Windows 98 / ME mode
2nd. It always runs in single core mode. After downloading process.exe to set how much cores a application can use the game freezes when it plays videos. The only time I can set it at dual core is when the race starts under pause menu.
What I did for the single core issue was write a simple cmd file that starts the game, when I select my track and car and the race starts. I press CRTL + ALT + DEL because CRTL + SHIFT + ESC doesn't work. Press enter in the command prompt & it starts process.exe with 2 cores enabled. Frames went from 13 to 28 so it's recommend if you have low fps.
What's up with NFS shift. I honestly never had these problems with any other NFS series even though they were crappy
C:\Program Files\Electronic Arts\Need for Speed SHIFT Demo>start shiftdemo.exe
C:\Program Files\Electronic Arts\Need for Speed SHIFT Demo>pause
Press any key to continue . . .
C:\Program Files\Electronic Arts\Need for Speed SHIFT Demo>Process -a shiftdemo.
exe 11
Command Line Process Viewer/Killer/Suspender for Windows NT/2000/XP V2.03
Copyright(C) 2002-2003 Craig.Peacock@beyondlogic.org
Setting Affinity Mask for PID 1892 'shiftdemo.exe'
Affinity Mask Successfully Set to 00000000000000000000000000000011
