Specs:
Intel® Core™ i5-4670K Processor (6M Cache, up to 3.80 GHz)
ASUS MAXIMUS FORMULA VI
PALIT GeForce® GTX 760 JETSTREAM (2048MB GDDR5)
HyperX blu black - 16GB Kit* (2x8GB) - DDR3 1600MHz CL10 DIMM
Seagate 1TB 7200RPM 64MB, ST1000DM003 (SATA 6 Gb/s)
EK-KIT H3O 240 HFX
CM Storm Scout 2
ASUS VS247H 23.6 Full HD LED Monitor (Black)
Mods:
0.0 Asus Maximus Formula VI with free Watchdog-literally
1.0 Remove the drive bay and cut the motherboard tray
2.0 made some shroud
3.0 put some holes below the reservoir
4.0 fitting on board and cpu
5.0 fitting on gtx 760
6.0 fitting on reservoir
7.0 fittings on pump
8.0 put some drain port on rad
9.0 rad fittings
10.0 do some loop
11.0 tested yahooo
12.0 do some cable management
13.0 finish with no light
14. my sarah build
Specs:
EK-KIT H3O 240 HFX
CM Storm Scout 2
Mods:
9.0 rad fittings
10.0 do some loop
11.0 tested yahooo
14. my sarah build
