My sim tray seems stuck [Case closed]
2,945 (0.65/day)
Fort Worth, TX
System Name LGA775 | BoX-Server
Processor Xeon E5450 OC3.6GHZ from 3GHZ | i3 3.4GHZ
Motherboard ASUS PQ5-EM | ASRock
Cooling 120MM Heatsink (2-FANs) | Custom HSK 90mm
Memory DDR2 2GB-x4=8GB | 8GB 2x4GB=8GB
Video Card(s) NVIDIA Quadro K2200 4GB | Intel
Storage 500\500/240/240GB SSDs 120GB Laptop IDE
Display(s) Asus 24"
Case DIYPC N1e-SPORT | CoolerMaster 110
Power Supply EVGA 550WATT | Rosewill 530WATT
Mouse Rosewill RGB
Keyboard Rosewill RGB
Software WiN10ET/WiN11ET
I have the Samsung A53 5G and I put my micro SD card in. It detect it but I want to remove it. I used a paper clip to alatch the tray but when I try to pull it, it just doesn't come out
Regeneration
NGOHQ.COM
3,151 (0.44/day)
Paper clip is too big for that hole. Use a smaller pin.
If the tray is damaged, you can buy one separately.
2,945 (0.65/day)
Fort Worth, TX
Display(s) Asus 24"
Mouse Rosewill RGB
no it fits. I found my removal but still...
3,195 (2.26/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
It depends on the SIM tray and paper clip. Here in the USA, paper clips come in different sizes. Hopefully OP had the sense to use an appropriate sized object or to try several. At least for my iPhones and iPads, the standard 1.25" paper clip works fine.
This is the same paperclip size that has worked for decades to eject optical drive trays, floppy disks, press recessed reset buttons, etc.
Well, OP has to get the old one out of the handset first, yes?
OP should try orienting the phone in different positions while trying to eject the SIM tray.
If it doesn't work, OP would be better off taking the handset to a cellphone store. They have more experience with such matters.
Count von Schwalbe
Nocturnus Moderatus
3,451 (2.73/day)
Knoxville, TN, USA
Ugh, last time this happened to me I ended up beating the tray into submission - banged it in the table with the tool down. I can't say I recommend the method unless you are getting a new phone.
2,945 (0.65/day)
Fort Worth, TX
Display(s) Asus 24"
Mouse Rosewill RGB
See. I thought just be easy with my nail and pull out but no it's stuck
Count von Schwalbe
Nocturnus Moderatus
3,451 (2.73/day)
Knoxville, TN, USA
Ok, if it is released, you should be able to pry it out. Gripping it lightly with a pair of pliers (small, non-needlenose pair recommended) and giving a bit of a tug should bring it loose.
The phone I had the issue with didn't want to go even that far.
2,945 (0.65/day)
Fort Worth, TX
Display(s) Asus 24"
Mouse Rosewill RGB
Yea I tried and scratched up the paint ha. I just buy a new one
2,945 (0.65/day)
Fort Worth, TX
Display(s) Asus 24"
Mouse Rosewill RGB
Regeneration
NGOHQ.COM
3,151 (0.44/day)
Are you insane? That'll break the clip tray
Your SD card or Sim card probably moved from its location and that's why it doesn't come off.
Just pull while shaking it from both sides and it will come out. If you have a needle use it to move whatever blocking it from coming out.
2,945 (0.65/day)
Fort Worth, TX
Display(s) Asus 24"
Mouse Rosewill RGB
I don't think... Either one is moved bc once I put back in they are working. Just odd this happened
Regeneration thank you but both sim and card went flying lol but found them
