Saakki
- Mar 3, 2008
- 301 (0.05/day)
- Finland
System Name | JGG |
Processor | Q6600 @ 3,4ghz |
Motherboard | Rampage Formula |
Cooling | Xigmatek, Nexus |
Memory | 1100 mhz Pi |
Video Card(s) | 6950 + Accelero Xtreme Plus |
Storage | 1tb+1tb |
Display(s) | Acer 19" LCD 5ms + 17 " Hitachi |
Case | Fractal Design Define R2 |
Audio Device(s) | X-FI |
Power Supply | XFX Core 650 |
Software | Win 7 ultimate x64 |
Benchmark Scores | Q6600 @ 3.5 ghz + and 6950 @ 6970 + |
Hello there. I decided to turn to you to ask what is going on with my new NAS, Netgear Stora 1tb. I have tried 2 different routers and several setups etc but the problem persists. The problem is that when I turn on Stora, everything is fine, for a minute. I can transfer maybe one big file to it but then the transfer speed drops to around 100 kbps / from 15 mb / second. Thats unbearable. I have to reset my router to make it work again but the problem doesnt go away. Is the problem in Stora setup or router settings or with the network adapter. Stora is in network with two computers and in the same router as internet connection from cable.
I have tried fiddling with NAT / upnp / firewalls on/off but not a cigar. At the best time I was able to transfer about 6 gb of stuff before the magical 100 kbps transfer rate cap became back. Routers tested with: TW-EA501 v3 and A-Link RoadRunner 44. Should I get a better router or something? Someone recommended me NetGear WNDR3700 but its a bit expensive + I dont use wireless at all. All connections in my place are using ethernet cables.
http://img821.imageshack.us/i/problems.png/
Thanks in advance.
- Saakki
Thanks in advance.
- Saakki
