CAPSLOCKSTUCK
Spaced Out Lunar Tick
- Feb 26, 2013
- 8,578 (1.92/day)
- llaregguB...WALES
System Name | Party On |
Processor | Xeon w 3520 |
Motherboard | DFI Lanparty |
Cooling | Big tower thing |
Memory | 6 gb Ballistix Tracer |
Video Card(s) | HD 7970 |
Case | a plank of wood |
Audio Device(s) | seperate amp and 6 big speakers |
Power Supply | Corsair |
Mouse | cheap |
Keyboard | under going restoration |
NASA engineers are testing the high-power solar electric propulsion systems that could soon push exploration missions further into deep space.
A stunning new image from the agency’s Glenn Research Center shows a Hall thruster ahead of ground testing in a vacuum chamber.
https://en.wikipedia.org/wiki/Hall-effect_thruster
The device is said to have three times the power of existing systems, and the experiments in the vacuum chamber will put it to the test of a simulated space environment, allowing engineers to see how it performs.
In the image, NASA engineer Dr Peter Peterson can be seen preparing the high-power thruster – a device that the agency says is ‘critical’ in the future of deep space exploration.
Called the Hall Effect Rocket with Magnetic Shielding (HERMeS), the device operates at 12.5 kW, making it far more powerful than current systems.
The agency plans to use these thrusters with solar electric propulsion (SEP) systems, which would allow for more cost-effective exploration of deep space, using 10 times less propellant than other systems.
The electrostatic Hall thrusters are equipped with advanced magnetic shielding, and are designed to provide ‘gentle but nonstop’ thrust for the duration of a mission.
Several Hall thrusters will be used for the Asteroid Redirect Robotic Mission (ARRM), operating at a total power of 40 kW with solar array wings that will supply 50 kW overall.
https://en.wikipedia.org/wiki/Asteroid_Redirect_Mission
