native resolution problem
2 (0.00/day)
i cant fix native resolution of 1920 X 1080 for my samsung SE390 monitor at windows 8.1. My hardware details are following
System Manufacturer Gigabyte Technology Co., Ltd.
System Model GA-78LMT-USB3 6.0
System Type x64-based PC
System SKU
Processor AMD FX(tm)-4300 Quad-Core Processor, 3800 Mhz, 2 Core(s), 4 Logical Processor(s)
Pls helm me in this issue
System SKU
what Res is it running at now? I'm a little confused.
What connection are you using to connect from the computer to the monitor?
If it is the VGA cable it won't show full H.D. resolution on the screen.
Yep you want to use HDMI cable, not VGA or DVI.
What makes you all think that 1080p wont be available on VGA?
I've had a bunch of VGA monitors going through me that had 1080p and they all worked as intended.
Besides, according to Gigabyte the IGP supports upto 192X1200 on all of the outputs.
  • Bits per pixel:
    • 24 bits per pixel support is mandatory in all resolutions supported.
    • Less than 24 bits per pixel is optional.
    • Up to 48 bits per pixel are supported in dual link DVI, and is optional. If a mode greater than 24 bits per pixel is desired, the least significant bits are sent on the second link.
  • Example display modes (single link):
    • SXGA (1,280 × 1,024) @ 85 Hz with GTF blanking (159 MHz)
    • HDTV (1,920 × 1,080) @ 60 Hz with CVT-RB blanking (139 MHz)
    • UXGA (1,600 × 1,200) @ 60 Hz with GTF blanking (161 MHz)
    • WUXGA (1,920 × 1,200) @ 60 Hz with CVT-RB blanking (154 MHz)
    • WQXGA (2560 × 1600) @ 30 Hz with CVT-RB blanking (132 MHz)
  • Example display modes (dual link):
    • QXGA (2,048 × 1,536) @ 72 Hz with CVT blanking (2 × 163 MHz)
    • HDTV (1,920 × 1,080) @ 120 Hz with CVT-RB blanking (2 × 143 MHz)
    • WUXGA (1,920 × 1,200) @ 120 Hz with CVT-RB blanking (2 × 154 MHz)
    • WQXGA (2,560 × 1,600) @ 60 Hz with CVT-RB blanking (2 × 135 MHz)
    • WQUXGA (3,840 × 2,400) @ 30 Hz with CVT-RB blanking (2 × 146 MHz)
DVI is perfectly fine still and situationally even better than older HDMI standards
Make sure the cable is plugged all the way in or try another cable.
Also, you haven't actually specified what GPU you're actually using, whether you've actually installed the drivers for it?
