[Case Gallery] Neat/Clean AMD Build: Redux
jeremiah23
4 (0.00/day)
Specs:
Phenom II X6 1090t
Radeon HD 6870
Patriot Inferno 120 GB SSD
Gigabyte GA-870A-UD3
G.Skill Ripjaw DDR3 1333 (8GB)
Antec Earthwatts 750W
WD Caviar Green 1.5 TB HDD (x2)
WD 500 GB
Nocturna Push/Pull CPU Cooler
Coolermaster HAF 922
Mods:
Aftermarket Mosfet heatsinks, CPU OC'd to 4Ghz
I re-wrapped all of the cords (SATA and power cords) with black cable wrap to tidy up the overall look of the case.
paint the inside of the case black. It's a shame that it doesn't come that way from the factory but I did it on mine and it looks 10x better
Excellent attempt with the Wire loom. From one person to another who used wire loom at one time..... get some Heat Shrink tube. It will help with the cleaner look.... also get a smaller size and .... try to combine as many wires into one loom for a cleaner look. Also a black coat of pain on the inside would look nice..... But awesome job bud!
Thanks for the feedback
Thanks for the feedback both of you. Yup, I really wanted to use heat-shrink but was afraid of it (both cost-wise and never having used it before). I will probably paint the inside of the case black when I get a bit more time this summer. This forum has helped me to learn a great deal!
