- Sep 28, 2005
- 3,518 (0.49/day)
- Canada
System Name | Alienware R10 Rebuild |
Processor | Ryzen 5700X3D |
Motherboard | Alienware Mobo |
Cooling | AIO (Alienware) |
Memory | 2x16GB GSkill Ripjaws 3600MT/s |
Video Card(s) | Dell RTX 3080 |
Storage | 1x 2TB NVME XPG GAMMIX S70 BLADE |
Display(s) | LG 32" 1440p |
Case | Alienware R10 |
Audio Device(s) | Onboard |
Power Supply | 1000W Dell PSU |
Mouse | Steelseries |
Keyboard | Blackweb Walmart Special Mechanical |
Software | Windows 11 |
I figure I would create this thread to list tools or get peoples suggestions for tools for DLSS.
DLSS Swapper - Github link
________________________________________________________________________________________________________
DLSS Updater - Github link
DLSS Tweaks - nexus mods
How to use video:
OptiScaler - Github
DLSS Swapper is a tool that allows you to conveniently download, manage, and swap DLSS, FSR and XeSS dlls allowing you to upgrade or downgrade DLSS, FSR and XeSS version in a game without the game needing an update.
- Steam
- GOG
- Epic Games
- Ubisoft Connect
- Xbox App
- Battle.net
- Manually added via the Add Game button.
What if you could update all the DLSS/XeSS/FSR DLLs for the games detected on your system?
Features
The current supported DLL included is DLSS 4. The current supported XESS DLL included is 2.0.1, please see the limitations here for game support.
- Supports updating games from the following launchers:
- Steam
- Ubisoft
- EA Play
- Xbox Game Pass (PC)
- Epic Games Launcher
- GOG Galaxy
- Battle.net (Note for Battle.net: Please ensure that the launcher is open before updating this launcher (this does not apply if you are entering a custom folder))
- A soft backup system for allowing restoration with DLSS Swapper.
- Support for updating Ray Reconstruction/Frame Generation/Streamline (Reflex Low Latency etc) DLL's.
- Support for updating XeSS/FSR/DirectStorage DLL's.
- A GUI!
- Support for manual folder locations.
Allows using DLAA anti-aliasing, customizing DLSS scaling ratios, overriding DLSS DLL version, and choosing different DLSS3 presets.
DLSSTweaks
Wrapper DLL that can force DLAA onto DLSS-supported titles, along with tweaking scaling ratios & DLSS 3.1 presets.
DLSS4 update:
DLSS transformer models can now be enabled via preset J and K - just make sure your game is updated to DLSS v310, and then set the presets in DLSSTweaks config ("DLSSPresets" section)
How to use video:
OptiScaler - Github
OptiScaler is a tool that lets you replace upscalers in games that already support DLSS2+ / FSR2+ / XeSS (1), now also supports enabling frame generation in those same games (through Nukem's dlssg-to-fsr3 or OptiFG). It also offers extensive customization options for all users, including those with Nvidia GPUs using DLSS.
For example, if a game has DLSS only, OptiScaler can be used to replace DLSS with XeSS or FSR 3.1 (also works for FSR2-only games, like The Outer Worlds Spacer's Choice).
Key aspects of OptiScaler:
- Enables usage of XeSS, FSR2, FSR3, FSR42 (RDNA4 only) and DLSS in upscaler-enabled games
- Allows users to fine-tune their upscaling experience with a wide range of tweaks and enhancements (RCAS & MAS, Output Scaling, DLSS Presets, Ratio & DRS Overrides etc.)
- Since v0.7.0+, added experimental DX12 frame generation support with possible HUDfix solution (OptiFG by FSR3)
- Supports Fakenvapi integration - enables Reflex hooking and injecting Anti-Lag 2 (RDNA1+ only) or LatencyFlex (LFX) - not bundled3
- Since v0.7.7, added support for Nukem's FSR FG mod dlssg-to-fsr3, only supports games with native DLSS-FG - not bundled3
- For a detailed list of all features, check Features
