- Jan 24, 2010
- 3,603 (0.64/day)
- Oregon, USA
System Name | GLaDOS |
Processor | AMD FX-9590 X8 4.7GHz |
Motherboard | ASUS Sabertooth 990FX |
Cooling | Corsair H80i v2 |
Memory | Corsair Vengeance 24GB (2x8GB, 2x4GB) DDR3 1600 MHz |
Video Card(s) | ASUS ROG-STRIX-RX580-O8G-GAMINGOC |
Storage | WD Blue 3D NAND 1TB Internal PC SSD |
Display(s) | 2 Acer S231HL 23" LED backlit LCD's on a Dual LCD stand |
Case | Corsair iCUE 220T RGB Airflow |
Audio Device(s) | Onboard - Corsair Void Pro Wireless |
Power Supply | Corsair 850HXi 850W |
Mouse | Corsair Sabre RGB |
Keyboard | Corsair K70 LUX RGB |
Software | Microsoft Windows 10 Pro 64 Bit |
Well, after a disagreement with the fan that comes stock with the L2 pro VGA cooler, I'm on the lookout for a replacement. The only issue is, I can't find any slim 92mm fans, and a 120mm is to large and messes with my cases airflow pretty badly.
Anyone know of where I could procure said 92mm fan? I'd prefer it without LED/non UV.
Because at this point I'm thinking about buying two small fans and mounting them next to each other.
