Processor | AMD 3900X \ AMD 7700X |
Motherboard | ASRock AM4 X570 Pro 4 \ ASUS X670Xe TUF |
Cooling | D15 |
Memory | Patriot 2x16GB PVS432G320C6K \ G.Skill Flare X5 F5-6000J3238F 2x16GB |
Video Card(s) | eVga GTX1060 SSC \ XFX RX 6950XT RX-695XATBD9 |
Storage | Sammy 860, MX500, Sabrent Rocket 4 Sammy Evo 980 \ 1xSabrent Rocket 4+, Sammy 2x990 Pro |
Display(s) | Samsung 1080P \ LG 43UN700 |
Case | Fractal Design Pop Air 2x140mm fans from Torrent \ Fractal Design Torrent 2 SilverStone FHP141x2 |
Audio Device(s) | Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 \Paradigm 7se MKII, Paradigm 5SE MK1 , Blue Yeti |
Power Supply | Seasonic Prime TX-750 \ Corsair RM1000X Shift |
Mouse | Steelseries Sensei wireless \ Steelseries Sensei wireless |
Keyboard | Logitech K120 \ Wooting Two HE |
Benchmark Scores | Meh benchmarks. |
OOps apparently it does have a preout, which would be the phono connections mark out as white on the bottom center of the unit.
Which i believe you would need some thing like this https://www.amazon.com/dp/B003OSXBSI/?tag=tec06d-20
EDIT: PA gear is not my thing how ever looks like you would need one of these from the amp to the speakers, i did notice that those speakers all so have the l1/4 inch option too.
https://www.amazon.com/dp/B000E1U4WY/?tag=tec06d-20
Maybe it's time to read some manuals.
Processor | 7900 |
Motherboard | Rampage Apex |
Cooling | H115i |
Memory | 64GB TridentZ 3200 14-14-14-34-1T |
Video Card(s) | Fury X |
Case | Corsair 740 |
Audio Device(s) | 8ch LPCM via HDMI to Yamaha Z7 Receiver |
Power Supply | Corsair AX860 |
Mouse | G903 |
Keyboard | G810 |
Software | 8.1 x64 |
Cooling | D15 |
Connect these:
Yes sir I did that. No sound. Is there a special setting on my receiver I need to have it in?
System Name | Juliette // My HTPC |
Processor | Intel i7 9700K // AMD Ryzen 5 5600G |
Motherboard | ASUS Prime Z390X-A // ASRock B550 ITX-AC |
Cooling | Noctua NH-U12 Black // Stock |
Memory | Corsair DDR4 3600 32gb //G.SKILL Trident Z Royal Series 16GB (2 x 8GB) 3600 |
Video Card(s) | ASUS RTX4070 OC// ASUS RTX 4060 OC |
Storage | Samsung 970 EVO NVMe 1Tb, Intel 665p Series M.2 2280 1TB // Samsung 1Tb SSD |
Display(s) | ASUS VP348QGL 34" Quad HD 3440 x 1440 // 55" LG 4K SK8000 Series |
Case | Seasonic SYNCRO Q7// Silverstone Granada GD05 |
Audio Device(s) | Focusrite Scarlett 4i4 // HDMI to Samsung HW-R650 sound bar |
Power Supply | Seasonic SYNCRO 750 W // CORSAIR Vengeance 650M |
Mouse | G903 and a Master Mouse MM710/No mouse, MS game copntroller |
Keyboard | EVGA / Logitech K400 |
Software | Windows 11 Pro // Windows 10 Pro |
Motherboard | AsRock X670E Phantom Gaming Lightning |
Cooling | Be Quiet! Dark Rock 4 |
Memory | G.SKILL Trident Z5 Neo DDR5-6000 32GB (2 x 16GB) |
Video Card(s) | Sapphire Radeon RX 7900 XTX |
Storage | Samsung 980 PRO Series 1TB, Samsung 980 PRO Series 1TB, Crucial P3 NVMe M.2 2TB |
Display(s) | LG OLED55G2PUA |
Case | Lian Li O11 Dynamic XL ROG Certified |
Audio Device(s) | Digital out to high end dac and amps. |
Power Supply | EVGA GQ 1000W |
Mouse | Logitech G600 |
Keyboard | Logitech G413 Carbon |
VR HMD | Oculus Rift CV1, Oculus Rift S, Quest 2, Quest 3 |
Software | Windows 10 Pro |
It's the exact opposite. How can this be?+24 db should be louder than 0db as you are boosting the signal.
Processor | 7900 |
Cooling | H115i |
Mouse | G903 |
Keyboard | G810 |
I'm confused on gain settings.
System Name | DEVIL'S ABYSS |
Processor | i7-4790K@4.6 GHz |
Motherboard | Asus Z97-Deluxe |
Cooling | Corsair H110 (2 x 140mm)(3 x 140mm case fans) |
Memory | 16GB Adata XPG V2 2400MHz |
Video Card(s) | EVGA 780 Ti Classified |
Storage | Intel 750 Series 400GB (AIC), Plextor M6e 256GB (M.2), 13 TB storage |
Display(s) | Crossover 27QW (27"@ 2560x1440) |
Case | Corsair Obsidian 750D Airflow |
Audio Device(s) | Realtek ALC1150 |
Power Supply | Cooler Master V1000 |
Mouse | Ttsports Talon Blu |
Keyboard | Logitech G510 |
Software | Windows 10 Pro x64 version 1803 |
Benchmark Scores | Passmark CPU score = 13080 |
Processor | 7900 |
Cooling | H115i |
Mouse | G903 |
Keyboard | G810 |
Because they are labeled wrong. They should go from -24 (min) to 0 (max).
Use the "zone 2 zone out" preouts. On my Onkyo TX-8050 there's a setting menu to turn zone 2 on, and make it fixed or variable, so my pro audio amp gets either the full signal or it varies with the receiver's volume level. Normally I set it to "fixed" and adjust volume on the pro audio amp.
The +dB is added to the input sensitivity range. A larger range will be quieter compared to a smaller range but the small range might clip.
The scale comes from mathematical terms representing a Relative volume scale. A newly installed receiver un-calibrated will have a volume range of -80.5 dB to +18 dB. -80.5 dB is almost a full mute, where +18 dB is the maximum possible volume output. Once your system is calibrated, 0 dB should provide you with full output from the amplifiers, meaning all other levels are relative to the loudest possible value (0 dB) and thus are expressed as a negative value. (ie: -20 dB) 0 dB on the receiver scale represents "reference" level and is arbitrary but is a well-known convention. Most new model receivers allow you the option of an Absolute volume scale or a 0 to 99 scale. If your receiver has the option for "Volume Display," it can be changed in the GUI menu under: System (or Manual) Setup - Option Setup - Volume Control - Volume Display.
Relative: -80.5 dB to +18 dB
Absolute: 0 to 99
System Name | Cumquat 2021 |
Processor | AMD RyZen R7 7800X3D |
Motherboard | Asus Strix X670E - E Gaming WIFI |
Cooling | Deep Cool LT720 + CM MasterGel Pro TP + Lian Li Uni Fan V2 |
Memory | 32GB GSkill Trident Z5 Neo 6000 |
Video Card(s) | PowerColor HellHound RX7800XT 2550cclk/2450mclk |
Storage | 1x Adata SX8200PRO NVMe 1TB gen3 x4 1X Samsung 980 Pro NVMe Gen 4 x4 1TB, 12TB of HDD Storage |
Display(s) | AOC 24G2 IPS 144Hz FreeSync Premium 1920x1080p |
Case | Lian Li O11D XL ROG edition |
Audio Device(s) | RX7800XT via HDMI + Pioneer VSX-531 amp Technics 100W 5.1 Speaker set |
Power Supply | EVGA 1000W G5 Gold |
Mouse | Logitech G502 Proteus Core Wired |
Keyboard | Logitech G915 Wireless |
Software | Windows 11 X64 PRO (build 24H2) |
Benchmark Scores | it sucks even more less now ;) |
