Need help in buying a battery back up UPS
2,715 (0.56/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
I have an old apartment with kinda bad power connection. The power will shut off for about 1-2 seconds every 1-2 months and its causing damage to computer mining equipment.
I bought some battery back ups this week but I dont know if the output is enough for 760watts and 6.47amps at 120volts in the US. The computer equipment are mining computers that draw 760watts.
The one I bought is this model.
https://www.bestbuy.com/site/cyberpower-450va-battery-back-up-system-black/3938808.p?skuId=3938808
At the bottom it says that the output is 120volt- 3.75 amps -- 450va 260W
Is this is the maximum output it will do. I only need this UPS for 1-2 seconds so the computer equipment doesn't damage anymore from a power loss.
Can anyone recommend one stronger or is this good enough.
13,949 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
If you look at the specs of that UPS, it shows 260 watts is the capacity. So clearly, that one is not big enough.
Note the formula to convert VA (volt amps) to Watts is:
VA x PF = W​
When no power factor (PF) is listed, you use 60%.
The PF for that UPS is an odd 57.8% since 450 VA x 57.8% = 260.1W
That's close enough to 60%
To find VA from W the formula is:
VA = W/PF​
So, to convert 760 W to VA you use:
VA = 760/.60
VA = 1266.66​
Therefore, you need at least a 1300VA UPS. I recommend a 1500VA.
22,175 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
2,715 (0.56/day)
Mouse Logitech m705
What billbright said. I one of these and it works well enough for my needs with a 750W system:
https://www.amazon.com/dp/B009TZTGWK/?tag=tec06d-20
What is your budget per UPS?
I am trying not to go over $100 per UPS x 12 mining machines.
I just need a UPS to protect against 1-2 second power loss. Last time it happened it caused some damage to the graphics cards.I dont need power to run the machines for 5 minutes just enough for those few seconds.
I guess the output has to be enough amps for 7-8amps. I dont know anything about UPS or battery back ups.
13,949 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Like power supplies, you want to invest is "good" UPS with AVR (automatic voltage regulation). You can find budget UPS but they typically have output voltages that are less regulated and they often have slower cut-over or response times.
ATX Form Factor standards for power supplies require them to "hold-up" output voltages when there is a loss of input power of just 17ms or less. That is not a lot of time for the UPS to sense there is an outage, then cut-over to battery backup. And sadly even many of the top quality power supplies have a difficult time meeting that 17ms requirement.
Since you are looking at supporting 12 systems, I recommend you contact UPS makers directly and see if you can cut a deal for a volume discount.
Norton
Moderator - Returning from the Darkness
14,104 (2.89/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
2,715 (0.56/day)
Mouse Logitech m705
What is 1500VA, is that 15amps total output
2,715 (0.56/day)
Mouse Logitech m705
13,949 (2.04/day)
Nebraska, USA
Mouse Logitech M190
VA = Volt x Amps.
Don't worry about just amps. You only need to worry about VA or Watts.
2,715 (0.56/day)
Mouse Logitech m705
Norton
14,104 (2.89/day)
Northeast USA
Mouse G300s
VR HMD N/A
ok, is the up UPS in the link good enough.
The ones you linked were rated for 1500VA/910watts iirc so they should be able to handle the 760watt load you quoted in the OP
2,715 (0.56/day)
Mouse Logitech m705
THanks @Norton, I would buy the ones that you linked but Newegg only had 2.
