Need help on mylogo for sabertooth z77
stevenchen
8 (0.00/day)
Canada
System Name WTF?
Processor Intel Core i7 3770K Unlocked Quad Core Hyperthreading Processor LGA1155 3.5GHZ Ivy Bridge 8MB Retail
Motherboard ASUS Sabertooth Z77 ATX LGA1155 DDR3 SLI 3PCI-E16 3PCI-E1 SATA3 HDMI DisplayPort USB3.0 Motherboard
Cooling Corsair Cooling Hydro Series H100I CPU Cooler System LGA1155 1156 1366 2011 AM2 AM3 FM1 & FM2
Memory Corsair Vengeance Black CMZ16GX3M2A1600C10 16GB 2X8GB DDR3-1600 CL10 1.5V Dual Channel Memory Kit
Video Card(s) ASUS GeForce GTX 680 DirectCU II 1019MHZ 2GB 6008MHZ GDDR5 DVI HDMI DisplayPort PCI-E Video Card
Storage Corsair Neutron Series GTX 120GB 2.5in SATA3 6GB/S Solid State Disk Flash Drive+WD2TGreen
Display(s) ASUS PA238QR 23IN Widescreen LED Backlit IPS LCD Monitor 1920x1080 6MS 50M:1 HDMI DisplayPort HAS
Case Corsair Vengeance Series C70 High Airflow Mid-Tower Case ATX 3X5.25 6X3.5INT 2XUSB3.0 No PS Green
Audio Device(s) N/A
Power Supply Corsair Enthusiast Series TX850M 850W ATX Modular Power Supply Active PFC 120mm Fan
Software Windows 8 Pro
I recently set up my new pc. I updated the bios 1708 for my sabertooth z77 with mylogo.
But now the logo screen is gone. just blank and straight into OS. Although it's faster than having a logo screen, I still want to have my customize logo.
Anyone know how to fix it? :roll:
More than likely, the board is showing that screen ,but boots faster than monitor, so it is not shown. ASUS BIOSes that added Windows8 support VASTLY improved boot times, when they boot right. :roll:
You can fix possibly by adding to the delay that the screen is shown, on this page(although there should be many more options with Windows8 BIOS). This screenshot is not form your board, but it should work in a similar fashion.
http://www.techpowerup.com/reviews/ASUS/Maximus_V_Formula-ThunderFX/images/bios_24.jpg
Thanks for answering.
I just tried use the reset buttom to reboot while my monitor is not in standby mode. All shown is several quick flash of the little slash(like DoS) and straight into windows 8 booting screen. So I don't think the costom logo ever show up.
Check those options in BIOS. Board does not boot in same manner when warm-booted, part of the Windows8 support. Monitor will still go into standby regardless of how the board was booted, when POST process is taking place, even if only momentarily.
