Need Help Understanding System Diagnostic Tools
2,817 (0.42/day)
louisiana
Processor Intel Core i5-12400F - Core i5 12th Gen Alder Lake 6-Core 2.5 GHz LGA 1700 65W
Motherboard GIGABYTE B760M--DS3H LGA 1700 DDR4
Cooling CPU - Thermalright Assassin King 120 SE / Case - cooler master 120mm rear case fan (Air cooling)
Memory CORSAIR Vengeance LPX 32GB (2 x 16GB) 288-Pin PC RAM DDR4 3200 (PC4 25600)
Video Card(s) GTX1060 6GB
Storage Samsung 1 TB 870 EVO SSD Main Drive / Samsung 500 GB 870 EVO SSD Backup Drive
Display(s) ASUS 23" LED Monitor
Case COOLER MASTER Centurion 5 (silver & black)
Power Supply CORSAIR RM-750X 750W Modular ATX
Software Windows 11 Pro 64bit Edition
when i run those diagnostic system checking tools what should i expect to find?
should there be no errors at all or are some errors normal? if so then how many errors of what type should i expect to find that are "normal" errors?
Which system diagnotic tools do you mean? Errors aren't very normal, but it depends what they are. Post a log file if you want, that way someone here will probably be able to translate them into plain English.
im using s&m testmem4 and it showed 1 address error found in ram memory, a bad ide cable, and a hdd surface error. i replaced the ide cable which seemed to solve my computer problems but i still keep getting a hdd surface test failure due to an error found and the 1 address error found in ram memory. i get no other info about the errors except that the test failed because of the errors. i ran the windows disk check which says it finds no surface errors on the disk and so far everythings working fine.
what do i make of the 1 address error found in memory and the hdd surface error found?
The error found in the memory means that you have dodgy ram, the error on the HDD probably means you have bad sectors - these can be isolated, but I'm not sure how (check disk might even do it, have you tried scanning for errors with that?). As for the memory, the only solution would be to lower your overclock (if you are overclocking that is) or to replace the stick of ram.
