- Aug 14, 2014
- 190 (0.05/day)
- France
Processor | 5800X3D |
Motherboard | MSI Prestige X570 Creation |
Cooling | Corsair Hydro H100i RGB Platinum SE |
Memory | Kingston 32Go 3600MHz |
Video Card(s) | Nvidia 4090 |
Display(s) | Asus XG27UQ + Asus PG279Q |
Case | Corsair Obsidian 750D |
Power Supply | Corsair RM850x White |
Hello,
I hope this is the right subforum for this topic which is regarding COD Modern Warfare.
The issue is that from time to time, I would go from 130 to 100 FPS in the same scenarios. After troubleshooting, I found out the only explanation to be a lower TDP usage during those performance drops.
Here is what it looks like when the game is running as expected
And where it is not
Please note that on both cases, the CPU usage is below 20%, the GPU usage is around 97-99% while both display temperatures under control.
Here is what I tried so far :
- Cleaning drivers, trying several older versions,
- Enabling performance mode on driver settings,
- Sliding core voltage, power limit and temperature limit to the max on Afterburner,
- Disabling both CPU and GPU overclocking and resetting the motherboard to default settings,
- Making sure that the GPU was running in PCIE 3.0 x16 mode
I'm at a loss since this behaviour only happens in this game and clearly seems to be related to the lower TDP usage, which I don't understand is happening in the first place, out of the blue.
I would like to read some feedback regarding this, hopefully there is a simple solution
And where it is not
