Need help upgrading to a new GPU
JoeToddv
2 (0.00/day)
I currently have a Nvidia GT 635 graphics card in my computer, i have an intel I5 processor, 8 gigs of ram, nothing too special. I was curious as to what my computer can handle, gpu-wise. If i were to get a crazy 2g card like the 750 ti or something even more outrageous like the 950, could my computer handle it? I really need an upgrade because I'm not able to play the games im wanting to due to poor performance.
Any suggestions? Pointers?
Thanks
It depends on how big/good your PSU is, not CPU/RAM.
750Ti and 950 aren't very power hungry either, so unless your PSU is pretty cheap, it's gonna be okay.
#3
JoeToddvNew Member
how can i tell what kind I have? I ahve never touched the pwoer supply at all on this, How many watts would i need to run it without issue?
Uh, open your PC and took a photo of it? Usually only need common Philips screwdriver to open your PC.
Refer to this guide, maybe it helps:
If your PC case has big window, you don't need to open it.
PSU is usually a square box with lots of cables coming out of it.
Sorta like this:
Usually there's a sticker on the side of it. In above pic it's from Corsair brand with obvious name (VS650) that refer to 650w rating.
Fill your specs in this link, and press 'Calculate' button.
http://outervision.com/power-supply-calculator
It's not very accurate but you could use it as guide.
First of all..Properly list your specs.
Is this a low profile case?
Did you build it? OEM? Make Model?
Under your Profile there is a System Specs tab. We need to know what case you have. These kind of questions drive me nuts
If you don't know what PSU then take a picture :banghead:
Geforce GT635 was an OEM card according to Nvidia's website, but it's really low powered (35W). Both upgrade paths don't require a lot of power, but more than the current one, so we really need to know your PSU.
I have a GTX750Ti and I love it. Small, quiet and very powerful!
It requires a 300W PSU, but with 60W max TDP and your currents specs almost any ATX PSU is going to be enough. When I just bought this card, I've tested the power consumption with few games and according to GPU-Z it rarely reaches over 75% of max TDP in real world situations(~45W).
GTX950 is cool, but it has a 90W TDP, requires 6-pin power connector and costs a lot more. In my case I cannot justify GPU upgrade from 750Ti, unless I go straight to GTX970 or higher.
If you are planning on buying a new card - get GTX950 and you might want to check your PSU specs.
Cheapest option: used or refurbished 750. Those go for under $100.
Also what resolution is your screen and what games are you wanting to play mostly?
I think its frustrating how many models NVIDIA comes out with now. I don't want to be one of those people that always suggests spending a little more but in the case of the GTX 950 I cant see how you couldn't spend an extra $40 for the 960. Its a big bump in performance and only $40 more.
To put it in perspective the difference in price between the 960 and the 970 is about $130, and the diff between the 970 and the 980 is about $150. So I think its much more logical to recommend people go with the 960 over the 950 as the difference is MUCH less than the other models.
Again I totally understand that everyone has a budget and $40 more may not be doable for you but I mean if you divide that $40 out over the time you plan to use the card, lets say just 1 year... well I think you should really try to get the 960. But I know you have to sort out the PSU as well.
Good luck.
