ct5098
- Aug 3, 2009
- 13 (0.00/day)
Processor | AMD Phenom II 955 BE @ 3.4 GHz |
Motherboard | MSI K9N2G Neo |
Cooling | Xigmatek heatsink |
Memory | 2 x 2GB DDR2 @ 800 MHz |
Video Card(s) | Sapphire 2GB Radeon HD 6950 |
Storage | 1TB Western Digital Black Edition |
Display(s) | Auria 25" LCD |
Case | NZXT tower |
Audio Device(s) | N/A |
Power Supply | 550 Watt |
Software | Windows 7 Home Premium 64-bit |
Hi, I'm new to Linux and bash scripting, and I could use a little help in figuring this problem out.
I have an Ubuntu server that I host a Ventrilo server on. When I start my server, I would like for the Ventrilo server to start automatically. I have a user, ventrilo, which runs the Ventrilo server. I've placed the following code in a file named "ventrilo" in /etc/init.d and I've run "chmod +x ventrilo". However, if I attempt to run the command "/etc/init.d/ventrilo start" the console states "ventrilo: command not found". The code below is the "ventrilo" script, but I'm 90% certain that my problem doesn't lie completely with the script. I'm not sure where to go from here though, and any assistance would be wonderful. Thanks.
****EDIT****Never mind, I was able to get it working by removing the quotations around $1
Code:
#!/bin/bash
VENT_DIR=/var/ventrilo
VENT_EXE=$VENT_DIR/ventrilo_srv
USER=ventrilo
case "$1" in
start)
if [ -e $VENT_DIR/ventrilo_srv.pid ]
then echo Ventrilo is already started
exit
fi
echo -n Starting Ventrilo:
su $USER -c "$VENT_EXE -f$VENT_EXE -d"
then echo done
else
echo failed
fi
stop)
echo -n Stopping ventrilo:
then echo -n
else
echo Venrilo is not started!
exit
fi
kill `cat $VENT_DIR/ventrilo_srv.pid`
sleep .5s
then echo failed
else
echo done
fi
restart)
$0 stop
$0 start
echo Usage: start stop restart
esac
exit
