Need help with network PLS
2,863 (0.46/day)
Brasil
System Name Sovereign // HTPC
Processor i7 3770k 4.2 // i7 3770k 4.2
Motherboard Maximus V Gene // Sabertooth Z77
Cooling Noctua D14 // Intel HSF
Memory 16GB Samsung // 16GB VengeanceLP
Video Card(s) Deciding // 660 DC2
Storage OS (X25-M), Data (Seagate 1TB) // Samsung 840 120GB & bunch of drives
Display(s) Samsung T240HD // LG TV
Case TJ08e // Grandia GD08
Audio Device(s) DT880 Pro 250 ohm // TV speakers
Power Supply Seasonic Plat 1000 // Seasonic Gold 760
Software Windows 8 Pro x64 // Windows 7 Pro x64
I have a ISP connected to a D-604, in the D-604 has a PC thats not mine, and I want to setup my other router a TEW-633GR so its just for my "room network" I manage to do this, but uTorrent gets lower download speeds.
I don´t want to connect the first router to the a LAN port because i want the firewall and increased safety from my TEW, how do i setup both? I tried to disable DHCP on 604 and all was working fine (utorrent slow though)
Connect the modem to the D-604's Internet Port.
Connect the TEW-633GR to one of the D-604's LAN ports.
Leave DHCP enabled on both.
Forward the utorrent port on the D-604 to the TEW-633GR(or even better, put the TEW-633GR in DMZ mode).
Forward the utorrent port on the TEW-633R to your computer.
If you don't forward the port through both routers, you will get worse speeds.
Will try it out
The DHCP should be in the same range? 604 is 0.100-199; TEW is 10.100-199
Will try it out
The TEW will receive a dhcp address from the 604. And the TEW will hand out addresses to your room network. All home routers use NAT and its not entirely wise to turn it off. So youd want dhcp to stay on.
Note you will get slower latency using another device as it is another router to go through
Will try it out
Yes, make sure they use different ranges.
