- Dec 16, 2007
- 836 (0.13/day)
- Canadia
System Name | Blood |
Processor | Intel Core 2 Quad Q6600 @ 2.4Ghz |
Motherboard | ASUS P5Q PRO @ stock settings |
Cooling | Antec Case fans (max) OCZ Vandetta 2 CPU cooler with a Kaze Jyuni 120mm fan 1200RPM+-100RPM 67.5CFM |
Memory | Patriot Viper Series 4GB 2x2GB DDR2 800Mhz 5-5-5-15 |
Video Card(s) | BFG NVIDIA GeForce GTX 260 OC MAXCORE 896MB PCIe 2.0 Core 216 @ stock settings |
Storage | Seagate Barracuda 500GB SATA 3.0Gb/s |
Display(s) | Acer AL2616Wd 25.5" 1920x1200 800:1 178degrees viewing angle 5ms S-IPS Panel |
Case | Antec Nine Hundred |
Audio Device(s) | Auzentech X-Plosion 7.1 with a coaxial cable connected to a Logitech z5500 |
Power Supply | BFG ES-800 800W |
Software | Windows Vista (soon to be Windows Xp, Vista, and Windows 7 triple boot) |
Yesterday, I had my 5870 at 1000 core and 1300 mem and 1.225v core voltage.
I could run any of the 3D tests for as long as I wanted. Today, it seems more unstable, those same tests crash, and sometimes they work.
GPU Burn-in crashes on all of the Open GLs, and Direct Xs.
How do I proceed? I want to keep my core and mem clocks. Do I increase core voltage? Decrease core voltage?
also: when I set the core voltage to 1.275v yesterday, it was unstable, but 1.225v seemed to be fine.
