Need Mobo Specs..Very urgent
7 (0.00/day)
System Name UnderMordor
Processor FX-8320
Motherboard Asus M4A97
Cooling Cooler Master Hyper 212 EVO
Memory 2 x 4 Gigs Corsair Vengance
Video Card(s) Asus R9 280x
Storage 500 Gigs WD Blue
Display(s) Samsung 22'' 1080p 75Hz
Power Supply SeaSonic S12II Series SS-620GB 620W 80 Plus Bronze Power Supply
Hi guys....
I m in a urgency of buying a decent CPU...I have 2 choices
1.Asus M2N VM DVI
2.Asus M2A VM..
Which is better....?And plz specify me a suitable graphic card for both....
If i go with Asus M2A VM can i use nVidia 8600GT Graphic card or else can i carry on with M2N VM or else is there any gud mobo in that range.....I m really in gr8 confusion....
Thanks in advance.....Plz sort out my problem....:banghead:
Motherboard spec links:
Asus M2N-VM DVI:
http://www.asus.com/products.aspx?modelmenu=1&model=1841&l1=3&l2=101&l3=567&l4=0
Asus M2A-VM:
http://www.asus.com/products.aspx?modelmenu=1&model=1568&l1=3&l2=101&l3=496
Both support AMD CPU's (processors) and both support PCI-E 16x for a graphics card.
Any PCI-E 16x capable card should work (which is probably about everything you can buy atm).
So the 8600 will work on both motherboards.
The M2N is supposed to be better for displaying High Definition video, but since you're buying a seperate graphics card, that shouldn't really matter.
As for the CPU, you need to know that the motherboard doesn't come with one installed. As I am not really educated about the current AMD processors, I can't give you solid advice.
Maybe some things you need to post so other people can also help you out:
- What will you be using the comp for? Gaming? Browsing? HD Video display? HTPC?
- Are you going for power or low energy consumption?
- Is it necessary to get a micro-ATX motherboard or can a normal size ATX fit?
Last but not least, Google is your friend. I had absolutely no problem finding the specs on the first hit I got typing those model numbers into Google.
