Need some help unbricking a Cable Modem
Sonido
356 (0.06/day)
USA
System Name Sonido
Processor E6600 @ 3.20 GHz (1600 FSB)
Motherboard abit IX38 QuadGT
Cooling Tt SpinQ (load @ 29c)
Memory TopRam SpeedRAM A.K.A "El Cheapo" @ 800 MHz
Video Card(s) Diamond HD 4870 (@ Stock)
Storage Primary: 500 GB WD
Display(s) 32" Samsung 1080p HDTV
Case Antec Twelve hundred (Modded Tri-cool fans)
Audio Device(s) On-board HD Audio
Power Supply 700W Rocketfish
Software Vista\7\Linux\Hackintosh
I could use a BlackCat cable method, but I don't feel like prying it open, soldering the header, buying the BC cable, and getting the software. It's too much trouble for this modem.
I have a SB4100. I've tried all the basics, including EB.
hmmm.....if unbricking dont work i have a SB5100 i could trade you
i was think maybe you had something you wanted to trade that worked :)
Lmao, I kinda figured that. I was kind of curious to see if that's what you meant, though. I was going to ask why...
Well, I have a DSL Duplex I can trade you, if you like? Can be mod'd for other services.
im not sure what that even does TBH...:)
It's all good. Everyone has to learn at some point, right? :)
It's a DSL Modem/Switch/Router w/ Wireless b & g. I do believe it can be used as a regular switch, too.
what happened to where the modem ended up bricked?
Huh? I think you're confusing the duplex with the modem I was describing in the OP. Am I right? Or are you asking how I bricked the cable modem?
how did u brick the modem
Oh, funny story. It's not really bricked, per say. It just refuses commands from Ethernet. I flashed it. It worked great, until I rebooted it. Now, it just refuses to allow me back in :(.
so maybe you could use the USB connection and flash back?
USB drivers don't work for x64. Trust me when I say I've tried everything. :laugh:
I don't even know if that would be possible.
so you dont have anything other than the dsl thing for trade?
Well, I have other hardware, but nothing that would justify a trade for a modem. I do have a nForce4 SLI LGA775 board from Gigabyte. But to trade for just a modem would be a bit off.
