Negative Pressure - no intake fans
Kammster
188 (0.03/day)
Guyana, South America
Processor Sempron 64 2800+ DH-E6 (@2Ghz - bios limit)
Motherboard DFI NF3 250-AL (@250 FSB - 2000 HTT)
Cooling 92mm + 80mm Exhausts / Amd HSF mod:80mm fan + VF700 cuLED [mod to x800 fan control]
Memory 1GB Buffalo DDR 400 @416 3-4-4-8 1T
Video Card(s) Sapphire X800 GTO (broken- sapphire is BAD)--256mb 6200
Storage WD 120 GB Caviar SE + 1GB Flash [80GB 7200.9 offline]
Display(s) 19" Samsung Widesceen LCD
Case Xtech cheapo
Audio Device(s) onboard - Realtek 6Ch
Power Supply Coolermaster eXtreme Power 550W w/ Antec 120mmLED
Software Windows XP SP2 + nforce 76.45 + nforce 5.10
How it works:
CPU : intake funnel + amd fan + 80mm exhaust (restricted vent holes) (31 deg idle)
Gfx : side panel intake vents + zalman + 60mm exhaust (39 deg idle)
PSu exhasut + intake vents in front of hardrive (32 deg idle)
chiptset 34deg (idle)
I just wanted to exhuast the hot air from the case before it statred to effect the generic psu, so i cut a hole in the thin sheet metal, and installed a 60mm fan for testing and i got a big surprise!
not only did hot air vent out faster but the other components got as much as 5 deg cooler.
before chipset hit: 43 deg under gfx card heat
after : 38 deg / 39 deg(silent)
the temp drop was also on the cpu load temp 42 to 39
but the gfx card was best; before my max temp never varied with clock frequency always 63 deg.
now 300:350 (barely 54 deg); 415:496 (59/60 deg)
my theory is: basic fliud mechanics volume in = volume out. the exhaust fans pull so much air out of the case that they not only pull in air thru the vents but also cause air in the case (hot air) to move in currents to the exhausts(2+psu).
i am 60mm(25mm thick) 12v@0.12V thta i got from a car parts store.
also tried a spare fan from a mircofin socket A cooler:
dynatron mircofin (15mm thick) 12v@0.25v top speed 5200 rpm (loud -48 db), i forgot the temps because it was too loud, @silent(5v) was same.
Kammster
188 (0.03/day)
Case Xtech cheapo
quick update
there is dust everywhere, any place than air can move there is dust, behind the hard drive the front grill thing has dust spikes like a fan blow it there.
had to take out the 80mm fan for another case, put in a 92mm and it really kicks
temps gpu @ 400:425 57core:45mem
and the temp falls fast when the load stops.
vibration from the fan on side panel was bad but got a idea from a generator room and used rubber strips for patching bicycles to dampen the noise.
7,662 (1.17/day)
c:\programs\kitteh.exe
Processor C2Q6600 @ 1.6 GHz
Motherboard Anus PQ5
Cooling ACFPro
Memory GEiL2 x 1 GB PC2 6400
Video Card(s) MSi 4830 (RIP)
Storage Seagate Barracuda 7200.10 320 GB Perpendicular Recording
Display(s) Dell 17'
Case El Cheepo
Audio Device(s) 7.1 Onboard
Power Supply Corsair TX750
Software MCE2K5
actually positive pressure is more desired than negative ...
kwchang007
3,962 (0.59/day)
Severn, MD, USA.
Processor C2D T7200@2 ghz vcore: .9875
Motherboard generic laptop board
Cooling fan control and antec notebook cooler
Memory 2 GBs@ 533 mhz ddr2
Video Card(s) x1400 mobile, overclocked: 526mhz core/ 882mhz ddr
Storage 120 GB@ 5400 rpm fujitsu
Display(s) 15.4" 1440x900
Audio Device(s) integrated
Software vista 32 bit home premium
really? so air just starts flowing out type stuff?
EDIT: I always though balanced pressure was the best?
Zeratul_uy
530 (0.08/day)
Montevideo, Uruguay
System Name EMMA <3
Processor AMD Athlon X2 3600+ Brisbane @ Stock
Motherboard GigaByte GA-M57SLI-s4 (I also hate it -.-)
Cooling Stock and many Fans :D
Memory 2GB G.Skill (2 x 1GB DDR-2 800 CL5-5-5-15) @ Stock
Video Card(s) ECS 8600GT @ Stock
Storage Samsung (120GB IDE)
Display(s) Compaq V70 (Plz Viewsonic 1903w hurry up!!!)
Case Case xD
Audio Device(s) Realtek dunnowat 7.1 onboard
Power Supply Eurocase 450w
Software Vista Ultimate x32
Benchmark Scores Poor, horrible xD
I got intake front, exhaust rear... That's the best setup i've tryed so far and works preety well.
Let´s see if i find some pic with my temps before my mobo dies...
Zeratul_uy
530 (0.08/day)
Montevideo, Uruguay
System Name EMMA <3
Case Case xD
Found it, Everest Temps right there, and Shitty BG with my name xD
Black = HD
Blue = GPU
Brown = CPU
Green = Mobo
And those aren't my best temps :p coz that ones was after running the bench xD
Best Idle were 25 HD, 20 GPU, 26 CPU and 19 Mobo...
Believe it or not :D
See'yas!
kwchang007
3,962 (0.59/day)
Severn, MD, USA.
Black = HD
Blue = GPU
Brown = CPU
Green = Mobo
See'yas!
i believe you. my friend is running his e6600 with stock cooling and thermal paste, and it idles around 28 when it was ~65 F. he has one intake on the front, one intake (cpu sleeve thing) one side, one exhust on side, one exhust on back, and the psu. very cool system, you can feel the room heat up (i guess that's not a good thing, lol) sounds kinda like a turbine when it's running though....in a good sort of way.
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
From my experience and a few of my IT buddies, they find a close match to a 1:1 ratio serves well, you have your exhausts up high and rear, intakes low and front, it helps replenish the exuasted hot air faster with cooler air than negative, since you have fans pumping air in. Posotive I believe would be more intake than exhaust, which is the least effecient method, it will not be able to remove the heat as quickly, which is the goal with OC'd PCs. If you have more air moving in the case, but not exhuasting hot air efficiently, you're trying to cool your components with hot air, doesn't make much sense, but posotive is supposedly the best way to keep dust to a minimum. I'd rather clean my PC more often and get more effective cooling. I may be backwards on those, but that's how I understood it.
Also, IRA, you gonna fill out your system specs in your User CP so we can see whatcha got running? I'm kind of curious, because it seems like you have some OC experience. Let's see what you have.
7,662 (1.17/day)
Cooling ACFPro
Display(s) Dell 17'
Case El Cheepo
Software MCE2K5
pc is currently down .. waiting on a vid card .. got a E6400 ... 2 gigs o ram, ABit AB9Pro, stock intel cooler for now
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
Nice, keep us posted on how it turns out!
Zeratul_uy
530 (0.08/day)
Montevideo, Uruguay
System Name EMMA <3
Case Case xD
Hahaha, mine is not sooo noisy, tested just all the fans, with the case empty :)cry: there is nothing in there) at 5 am, when the house is ultra silent and the only fan that made a noise, was lubricated and now is not noisy xD Ultra Silent Zera Cooling lol \o/
kwchang007
3,962 (0.59/day)
Severn, MD, USA.
lucky you, his sounds like a turbine when he starts it up pheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeewwwwwww but it does a good job at keeping it cool. and if he bought a fan controler, im sure he could leave them all at low and still get really good idle temps.
Zeratul_uy
530 (0.08/day)
Montevideo, Uruguay
System Name EMMA <3
Case Case xD
Hahahaha, he need limits on those rotations xD hahaha the "phewww" thing was really funny hahaha
kwchang007
3,962 (0.59/day)
Severn, MD, USA.
lol thank you. he sort of does....i mean he's usally blasting music, or playing his guitar really loud....so the pheww isn't noticable. actually now that i try and remember, once it's running, you don't really notice it, it's just when you start it and it goes phewww, here's the case
Zeratul_uy
530 (0.08/day)
Montevideo, Uruguay
System Name EMMA <3
Case Case xD
Looks really sexy, mine is self-made hehe i cutted, drilled and tweaked myself... I'll upload some pics :D
And for the noise thing, my Heatsink used to do tons of noise too lol it wasn't "phewww" it was like "hhhhhhhhhhhhheeeeeeeeee" and was really annoying coz I couldn't hear at low volume xD and when the night is silent, arround 3~5 hs am, it was really unbearable... So I've reduced the RPM's of it and it worked still at good temps and ofc with much less noise... :D
(Taken with a webcam, my digicam is broken)
Before painting and mounting of the side Metacrylate (dun remember if it is spelled right) panel
After painting and mounting of the side Metacrylate pannel and before the lights and side 120 mm x 120 mm fans \o/
Front
Rear
Metacrylate side
And the other side (nothing special on it at the pic, made an AMD logo with vinyl on it)
When I got my digicam working I'll post it on rate my case, now it's finished xD
kwchang007
3,962 (0.59/day)
Severn, MD, USA.
Front
Rear
Metacrylate side
yeah, it's sexy, just no side panel, and i don't think he wants to mod it (he's not even overclocking :wtf:). you have no idea how many cases we had to go through....it'd be like ....too blue....not blue enough....not enough fans.....to white (some weird stuff) but now....sexiness. wow, nice case. id defiantly give you a good rating (as long as you have good cable mangment, etc, the case is nice though)
Zeratul_uy
530 (0.08/day)
Montevideo, Uruguay
System Name EMMA <3
Case Case xD
Pics are way crappy, the cables were tied and moved away to let space for airflow, but now (before I taked all off) they were covered with a green (dunno how to say it lol) hmm thing xD and some green lights... It was nice... :D
kwchang007
3,962 (0.59/day)
Severn, MD, USA.
green!!! :D a much different color than the normal blue.....i think i like green.....hmmm...actually, i think i like no lights and a slient computer so i can sleep with it on, of course since slient is not possible....LIGHT IT UP!
Zeratul_uy
530 (0.08/day)
Montevideo, Uruguay
System Name EMMA <3
Case Case xD
It was everything black (Mate? it's ok?) but painted the inside of fluo green, and with the lights it rox ^^
Personally, I love black mate and fluo green \o/
kwchang007
3,962 (0.59/day)
Severn, MD, USA.
lol i meant lights when i said green. just cause...well....idk maybe it's because our grass is dying. i think it'd be intresting to see something with a UV light, are there any case mods here that have a UV lighting?
Zeratul_uy
530 (0.08/day)
Montevideo, Uruguay
System Name EMMA <3
Case Case xD
I could change the green lights by UV lights... If you rate me 10/10!! haha
Already though it but preffered green ones, I can give a try :D
7,662 (1.17/day)
Cooling ACFPro
Display(s) Dell 17'
Case El Cheepo
Software MCE2K5
from the Ideal Gas Law , pV=nRT. Rearranging we get n=(pV)/(RT), so increasing the pressure increases the number of air molecules to conduct away heat.
im just theorizing still ...
Bless
Kursah
Super Moderator
14,764 (2.18/day)
Missoula, MT, USA
I tested the positive air induction method, my temps increased by quite a few degrees C. The Ideal Gas Law makes sense, but at least in my application using More CFM Out than In (not by too much, based on est. fan airflow from specs) was the coolest airflow based solution. But if a few people try removing their case exhaust fan and only using PSU fan for exhaust, leaving intake installed and running, compare to current temps. That's the best way to verify is to try it out and see results with your own eyes.
IRA, you have any goals set for OC-ing that 6400?
7,662 (1.17/day)
Cooling ACFPro
Display(s) Dell 17'
Case El Cheepo
Software MCE2K5
yeah, i dont want to burn it up, lol. i live ina tropical country so 2.8 - 3.0 will do ... or 3.2 when im going to go crazy. i got a freezer 7 on the way still
